How Is Work Calculated When Moving an Electron Between Two Spherical Shells?
  • Thread starter Thread starter ku1005
    Potential Work
ku1005
Two conducting spherical shells are concentric, with radii of 0.70 m and 1.60 m. The electric potential of the inner shell, with respect to the outer shell, is +1050 V. An electron is transported by an external force from the inner shell to the outer shell. The work done by the external force is closest to:
Solution: 1.68 * 10^16 J
http://img139.imageshack.us/img139/394/potentialenergyworkqrc7.png
Well, I thought I would have to encorporate one of the above formulas, however, I couldn't seem to use any of them...then, I decided I would use
qV = U...and plugging this in it works...
ie (1.6*10^-19C)*(1050V) = 1.68*10^-16 J
HOWEVER- I hate simply plugging in values and would like to actually understand...would anyone be able to explain where this formula comes from/how it is derived...or point me in the right direction as to understanding...cheers i appreciate your time!
cheers
im an idiot...
seen as Potential Energy Difference = Work Done
And we know Potential = Energy per unit charge, it makes sense that the potential difference of 1050V multiplied by the charge concerned (ie electron) will give the Change in Potential Energy and thus the work done.
Is this corect thinking?
Thanks again if you read this
Yes, that's correct. You're looking for the potential difference betwen the two shells which happens to be +1050 V, so PE = qV is the correct formula to use.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
