Work done in moving the plates of the capacitors
The discussion focuses on calculating the work done in moving a charged parallel plate capacitor from separation distance d to d1. The initial energy is given by 1/2CV², where capacitance C is defined as Aε/d. As the capacitor is moved, both capacitance and potential change, leading to a final capacitance Cf and potential Vf, with the electric field E remaining constant due to the condition r>>d. The work done is derived as AεV²(d1/d - 1)/2d, confirming the correctness of the approach. The alternative method using U=Q²/2C is noted as simpler, given that charge Q remains constant for a disconnected capacitor.
bs vasanth
A parallel plate capacitor of circular cross section r>>d, and separation d. It is charged to potential V then disconnected from the circuit . What will be the work done in moving the capacitor from d to d1?
Answer:
Here the initial energy is 1/2CV^{2}
Where C=Aε/d
While moving the capacitor both the capacitance and potential change:
Cf= Aε/d1
Vf=∫E.dl (with the limits 0 to d1)
Vf= E*d1
We know that the E doesn't change ( Under the approx. as r>>d )
Therefore initial potential and final potential can be related as V= E*d
Vf=V*d1/d
Work done = 1/2( Cf*Vf^{2} - C*V^{2} )
= Aε/2 ((V*d1/d)^{2}/d1 - C*V^{2}/d )
= AεV^{2}( d1/d -1)/2d
I want to know if this answer is correct.
It's easier to use U=Q^2/2c because Q doesn't change for a disconnected capacitor, but your answer is correct.
Likes 1 person
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
