Work, Energy and Power question
The cyclist's maximum velocity on level ground is v, while uphill it is 1/2v, and downhill it is av. The initial calculations incorrectly assumed air resistance is proportional to the square of the speed rather than the speed itself. The correct approach shows that the force equations need to reflect this linear relationship. The error in the calculations led to an incorrect value for a, which should be reevaluated based on the proper understanding of air resistance. The discussion emphasizes the importance of accurately interpreting the problem's conditions to arrive at the correct solution.
gaobo9109
A cyclist develops constant power when cycling. The air resistance is proportional to the speed of cycling. When he cycles on level ground, the maximum velocity he can attain is v. When he cycles up a slope, his maximum velocity is 1/2v. If he cycles down the same slope, his maximum velocity is av. Ask what is the value of a.
The cyclist exerts the same amount of force on the bike at all velocity,thus
On level ground: F = kv2
cycling up a slope: F = 1/4kv2 + mgsinθ
kv2 = 1/4kv2 + mgsinθ
mgsinθ = 3/4kv2
cycling down the slope: kv2 + 3/4kv2 = k(av)2
a2 = 7/4
a = (7/4)1/2
But this is not the correct answer. Can anyone tell me where did I go wrong?
You assumed that the air resistance was proportional to the square of the speed (kv^2), when it is given that it is proportional to the speed (kv).
