Work integration application problem, answer check
The discussion centers on calculating the total work done in lifting a leaky bucket filled with water. The initial calculations for the weight of the bucket and rope were discussed, leading to a derived work function. However, discrepancies arose when comparing the calculated total work of 13,950 ft-lbs with the expected value of 2,430 ft-lbs for a non-leaking bucket. Participants emphasized the importance of correctly applying integration and understanding the units involved, clarifying that the force function must not include an additional variable in the integrand. Ultimately, the conversation highlights the need for careful attention to the definitions and calculations of work in physics.
8point1
A leaky 6lb bucket is lifted from the ground to a height of 30ft at a constant speed with a rope that weighs .5lb/ft. Initially, the bucket contains 60lbs of water, but the water leaks out at a constant rate and finishes draining just as the bucket reaches the 30ft level. How much total work is done lifting the bucket?
Function I found for the weight of the rope: (15-.5x)
Function I found for the weight of the bucket: (60-2x)
so adding all together I got = 6 + (15-.5x) + (60-2x) (Δx) (x)
then simplified to get the work function = 81x-2.5x2dx
integrated work function 81x-2.5x2 over 0 to 30 and got 13950 ft/lbs total work.
Always look at your answer to see if it is realistic to you. Suppose the bucket were not leaking and the rope was coiled up inside the bucket. Total weight of rope laden bucket is 60+6+15 = 81 lbm. To raise 81 pounds to a height of 30 feet is only 2430 ft-lbm. How can your answer be a larger number?
Another hint when you are deriving equations. Make sure the units you end up with jive with what you seek.
Thanks for your help. Obviously my answer is way high. I will keep working at it.
Concerning the units, what does lbm stand for?
Same as lbf in this case. I use them interchangeably when I'm on earth. : )
You are going about it in the correct manner. You just have a slight mistake. How is work defined?
Got to hurry on this. My happy hour begins at 4 PM EDT.
W=force x distance
I'm not getting 81 pounds as 2430 ft/lbs
(81 pounds)(distance) = W
81x=W
so integrate 81x over 0 to 30, and I'm getting 36450... what the heck.
ok, 81 x 30 = 2430, but shouldn't I be integrating the work function to get the total work (area)?
The work function is force times distance. The force is 81 pounds. The distance is dx. remember, your answer must have the units of ft-lbs. The integrand must have the units of ft-lbs. You are putting an additionl space dimension in it.
W = integral (F * dx) from 0 to 30. Integral of F * dx is F*X evaluated from 0 to 30. Answer is 81 * 30 = 2430.
Do you see where you have gone awry?
I guess I'm not understanding how distance is Δx. I thought that was the width of the "slice" of work done at xi.
dx is the width of the slice. Integration is simply a method that 'adds' up all the little slices letting the function take on its different values as the summing progresses over the limits of integration. Delta x in calculus terminology (when it approaches 0 in the limit) becomes dx.
Work is the area under the force-distance curve. Suppose you have a constant force and you graphed it with force on y-axis. The work would be represented by the area of the rectangle because that area is force multiplied by distance. Rectangle's height would be the force (y-axis). dx is a slice which is a very small rectangle whose height is F and whose width is dx. dW, the area of the slice, is F * dx. Note that the units of F*dx are ft-lbs. Since I indicated above that integration is basically a summing procedure, the units do not change. (3 apples plus 4 apples is 7 apples).
You have inserted an extra space dimension in your integration. Delta W is W multiplied by delta x. dW is W multiplied by dx. In the limit as one likes to say in 'calculese', the delta x becomes dx.
In your problem the force is not constant. The function you specified for it is correct. What is wrong is that you have inserted an extra x in the integrand.
16K
