How Does the Work-Kinetic Energy Theorem Apply to Electron Acceleration in TVs?
  • Thread starter Thread starter sn3t
    Energy Theorem
The discussion focuses on applying the work-kinetic energy theorem to calculate the kinetic energy of electrons in a television's electron gun. The kinetic energy of an electron as it exits the gun is calculated to be approximately 3.77 x 10^-16 Joules. The participants discuss the correct method for determining the electric force acting on the electron, emphasizing that it should be derived from the kinetic energy divided by the distance between the plates. The acceleration and time of flight calculations are also addressed, with some corrections suggested for the initial approach. Overall, the conversation highlights the importance of accurately applying physics principles to solve problems related to electron acceleration in TVs.
sn3t
In the neck of the picture tube of a certain black-and-white television set, an electron gun contains two charged metallic plates 2.80cm apart. An electric force accelerates each electron in the beam from rest to 9.60% of the speed of light over this distance. a) determine the kinetic energy of the electron as it leaves the electron gun. Electrons carry this energy to a phosphorescent material on the inner surface of the television screen material making it glow. For an electron passing between the plates in the electron gun, determine b) the magnitude of the constant electric force acting on the electron, c) the acceleration, and d) the time of flight.
Electron mass = 9.10938188 * 10^-31 kg
C = 299792458 m/s
Electron velocity = 28780075.968 m/s (.0960 * C)
Distance between plates = .028m
KE = 1/2m* v^2
F= mass * acceleration
a) KE = 1/2m * v^2
= 1/2(9.10938188*10^-31kg) * ( 28780075.968m/s)
= 3.77261759 * 10^-16 Joules
b) F=m*a
= (9.10938188*10^-31kg) * [ (28780075.968m/s)^2 / (.028m) ]
= 2.694722685 * 10^-14 N
c) a = F/m
= 2.694722685*10^-14N / 9.10938188*10^-31kg
= 2.9581839*10-46 m/s^2
d) ?
and I am not sure if my parts b and c are correct
b is not correct, you should divide the KE by the distance.
ehild
ah yea you're right it's N*m then when I divide it cancels out.
w= f * d
so ke = f * d
ke/d = f?
The change of the KE is equal to the work. But initially, KE=0.
Just divide your 3.7726 * 10^-16 Joules by 0.028 m.
ehild
