Work Done by a Force: A Breakdown
Work done by a force is indeed equal to the sum of the work done by its components, as demonstrated through the scalar product of force and displacement. When a force F acts on an object over a displacement d, the total work can be calculated using the formula W = F · d, which incorporates the angle between the force and displacement vectors. For instance, if force F is broken down into its x and y components, the work done by each component can be calculated separately and summed to yield the total work done. This principle holds true in both one and two-dimensional scenarios, confirming that the work done by a force is additive. Understanding this concept is crucial for analyzing forces in physics.
IMGOOD
Is a work done by a force equal to the sum of the work done by the its components?
Try to think of an example to prove/disprove your point. Let a force F be doing some work on a displacement d. Define the work and look at the scalar product.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
