Would an object heat up or cool down more quickly?
  • Context: Undergrad
  • Thread starter Thread starter Naser Tay
    Cool Heat
In a scenario involving two identical objects placed in rooms at 25°C, one at 0°C and the other at 50°C, the object at 50°C will reach room temperature first, according to Newton's Law of Cooling. This principle indicates that the rate of heat transfer is influenced by the temperature difference between the object and its environment, as well as the heat convection coefficients. Additionally, water condensation on the cooler object may initially enhance heat transfer, but could later create an insulating layer that slows the process.
  • Understanding of Newton's Law of Cooling
  • Knowledge of heat transfer principles
  • Familiarity with heat convection coefficients
  • Basic concepts of thermal conductivity and insulation
  • Research Newton's Law of Cooling in detail
  • Study heat transfer mechanisms, focusing on convection and conduction
  • Explore the effects of condensation on heat transfer
  • Investigate thermal insulation materials and their properties
Students and professionals in physics, engineering, and environmental science, as well as anyone interested in understanding heat transfer dynamics in thermal systems.
Naser Tay
If we have two identical objects each placed in rooms at 25°C room temperature. In the first room, the object is at 0°C. In the second room, the object is at 50°C. Which object will reach the room temperature of 25°C first?
Science news on Phys.org
Are you familiar with Newton's Law of Cooling? What does it tell you about this situation?
Assuming the same heat capacity for the two objects (independent from temperature) it is mainly a matter of heat convection coefficients. eg. if the objects are fixed at the ceiling the hotter one will reach 25 C first.
Besides, water condensation on the cooler object surface at first will accelarate heat transfer but after some time it may produce an insulating layer that will also have to heat up to 25C and partly vaporise.
  • · Replies 109 ·
  • · Replies 32 ·
  • · Replies 25 ·
  • · Replies 21 ·
