Would someone me out with this question?
  • Thread starter Thread starter yabadabado111
An object is visible when the light hitting it is reflected, and the discussion focuses on whether this reflection is even or uneven. The consensus leans towards unevenly reflected light, as rough surfaces scatter light in various directions, making the object visible. In contrast, smooth surfaces reflect light more uniformly, concentrating it. The distinction between the two types of reflection is crucial for understanding visibility. Ultimately, uneven reflection allows for better visibility of objects due to the scattering of light.
yabadabado111
Would someone please help me out with this question?
You can see an object when the light hitting it is?
Unevenly reflected
Evenly reflected
I know it's not the other two(absorbed or transmitted), but I am stumped between these two.
I know it's reflected, but some sources say each. :smile:Nevermind, I think it is Unevenly reflected
A rough surface is uneven - lots of little surfaces pointing in all different directions. A smooth surface have lots of small surfaces pointing mostly in the same direction - very little protrusions or indentations. Smooth surfaces concentrate light while rough surfaces scatter incoming light in different directions.
