MikeGomez said:
At a fundamental level, the reason that gravitational mass and inertial mass seem to be that same is that they are the same, not because nature conspires to make them appear the same.
I agree that this is what General Relativity says. Whether this is "the correct explanation" is still, strictly speaking, an open question, since General Relativity is not a theory of everything. But that's beyond the scope of this discussion.
MikeGomez said:
The body above the Earth experiences a gravitational field.
No, it doesn't. It's in free fall; it feels no force, no acceleration, and no "field".
MikeGomez said:
What is surprising is that what appears to be a different situation in the case of the body in freefall in the accelerating elevator is actually no different at all. There is a real gravitational field experienced by the body in freefall in the elevator.
No, there isn't. The body in free fall in the elevator, just like the one above the earth, is in free fall, feeling no force, no acceleration, and no "field".
MikeGomez said:
Now consider the body in the accelerating elevator on the floor of the elevator. The body experiences a 1g acceleration due to the acceleration of the elevator. Comparing this with situation with a body on the surface of the Earth under the influence of gravity, it might appear that the two situations are different, but that is not the case. The body on the surface of the Earth experiences a real inertial acceleration.
Except for the word "inertial", which does not belong there (if you wanted to add a qualifier to the word "acceleration" here, it should be "proper"), I have no problem with this.
MikeGomez said:
These examples assume the size of the bodies under consideration are small enough that they have negligible internal stress (particle).
No problem here, although I would phrase it that we are assuming the bodies are small enough that we can model them as point particles with no internal structure, since that's a more general statement than just saying they have negligible internal stress.
MikeGomez said:
That is to say that they experience no local tidal effects
Fine.
MikeGomez said:
but will experience time tidal effects if their trajectory takes them along a path that will do that as has been pointed out.
No. "No tidal effects" means "no tidal effects", period. There's no difference between "time tidal effects" and any other tidal effects. (To put it another way, "local" has to mean "local in both space and time".) They're all disallowed if we're going to talk about the equivalence principle. See below.
MikeGomez said:
Einstein could have chosen another situation to describe, such as a particle in a varying gravitational field, in which case an elevator might not be the appropriate non-gravitational counter part, but the equivalence principle would still apply
No, because "varying gravitational field" brings in those "time tidal effects", which aren't allowed. See below.
MikeGomez said:
at the heart of the equivalence principle is the equivalence between inertial mass and gravitation mass, not any inertial or non-inertial reference frame.
Agreed. See below.
MikeGomez said:
What is pertinent to the equivalence principle is that sufficiently small regions in spacetime (such that the effect of gravitation can be neglected) can be considered such that the invariant laws of physics of Special Relativity can be extended to include the non-inertial frames of reference in General Relativity.
Wrong, even by your own standards, since you just said frames were not what was important.
The equivalence principle is the statement that, in a sufficiently small region of spacetime (such that tidal effects can be neglected--all of them, including "time tidal effects"), the laws of physics take their special relativistic forms. Since those laws can be written in such a way as not to require or assume any frames at all, inertial or non-inertial, the EP does not say or need to say anything about frames. Frames are a convenience for computation. And since the equivalence between inertial and gravitational mass is necessary for the laws in a small enough region of spacetime to take their SR forms, that equivalence can indeed be viewed as part of the EP.
The reason all tidal effects ("time" or otherwise) are disallowed is that the laws of SR do not allow them, so if the laws of physics in a small enough region of spacetime are going to take their SR forms, the region must be small enough for tidal effects--all of them--to be negligible. It has to be all of them because "region of spacetime" means "region of
spacetime"; its size in time is limited just like its size in space. Otherwise we would see effects that do not match the SR laws (like two free-falling objects starting out at rest relative to each other but not staying at rest relative to each other).
MikeGomez said:
Done. See above.
