MHB Writing an Algorithm to Check Depth of Leaves in an Ordered Tree
The discussion focuses on creating an algorithm to determine if all leaves in an ordered tree, derived from a binary tree, are at the same depth. Participants clarify the definitions and relationships between ordered trees and binary trees, emphasizing that an ordered tree can have multiple children per node, while a binary tree cannot. The algorithm should traverse the tree to find the depth of each leaf, utilizing a pre-order traversal method. It is noted that during traversal, the depth of each leaf should be recorded and compared to ensure uniformity across all leaves. The conversation concludes with a consensus on the approach to implement the algorithm effectively.
evinda
MHB
Hello! (Wave)
I want to write an algorithm, that implements an ordered tree(not necessary binary tree). It should check if all the leaves of the ordered tree (that is implemented from the binary tree) are at the same depth.
Could you give me some hints how I could do this? (Thinking)
Technology news on Phys.org
Suppose that we have, for example, this tree:
Could you explain me how we found this binary search tree:
in order to make operations at the first tree? (Thinking)
This isn't the right corresponding binary tree, right? (Thinking)
Because, I read that at a binary search tree, each node has no more than two child nodes.
evinda said:
Hello! (Wave)
Hi! (Blush)
What should the algorithm implement? (Wondering)
An ordered tree (not necessarily binary)?
Or a test whether a binary tree has all leaves at the same depth?
Or a test whether an ordered tree, that is constructed from a binary tree, has all leaves at the same depth?
Or something else? :confused:
This seems to be the wrong way around. :confused:
If we have a tree like the second one, we can convert it into the binary tree that is shown first. (Wasntme)
Check. $\checkmark$
I like Serena said:
Hi! (Blush)
The algorithm should test, whether an ordered tree, that is constructed from a binary tree, has all leaves at the same depth.. (Nod) (Blush)
A ok.. (Nod) But, could you explain me how we can do this? (Thinking)
Actually, it's still the wrong way around.
I only know how to construct an ordered binary tree from an ordered tree. (Doh)
Well, we start with an ordered tree, which is not binary, as in your example where the root has 3 children.
Then we keep the link of each node to its leftmost child, and we remove all other child links, replacing them by sibling links.
Presto! An ordered binary tree. (Whew)
So, does this mean that we take the root, its child is the leftmost node from the next level and the other nodes of this level are the siblings of the leftmost node and so on..? (Thinking)
Or have I understood it wrong? :confused:
That sounds right.
Those siblings become child, grandchild, and great grandchild. (Nerd)
I like Serena said:
That sounds right.
Nice.. (Nerd) And how can we find the depth of the leaves? (Thinking)
Count the number of edges from the root to each leave? (Thinking)
How do we know where the leaves are, at the ordered tree? (Thinking)
If the root has any nodes connected to it, it's not a leaf, but an internal node.
The connected nodes are the children of the root, which are each at depth 1. (Thinking)
If any child has nodes connected to it other than its parent, it's not a leaf, but an internal node, and those nodes are in turn its children, which have a depth that is 1 greater. (Wasntme)
Any child that has no other nodes connected to it other than its parent, is a leaf.
It has a depth that is 1 greater than its parent. (Nerd)
So, do we conclude the following? :confused:
The node a is not a leaf.
The node b is the only child of a.
The nodes c,e are not leaves, and also they are children of b.
The only leaves are k,l,i.Or have I understood it wrong? (Worried)
You have understood it right! (Nod)
Nice... (Smile) And, do we have to traverse now the tree in pre-order/ in-order/ post-order, in order to find the leaves? (Thinking)
Or, do we have to do something else? :confused:
Yes. (Nod)
Those are the most common ways to traverse a tree to do anything with it.
In your case to figure out where the leaves are and what their depth is. (Nerd)
I like Serena said:
Yes. (Nod)
In our case, do we have to traverse the tree in pre-order? (Thinking)
Actually, the algorithm to traverse a tree implements all 3 forms at once.
For this problem it's not relevant which order to take. (Wasntme)
When we apply all forms at once, don't we traverse three times the tree? (Worried)
Or am I wrong? (Thinking)
Assume your tree is implemented with nodes with child (youngest child) and sibling pointers. For such a tree, a node p is a leaf if and only if p.child == null.
So first find the depth of some leaf node for a non-empty tree:
Code:
depth=0;
p=root;
while (p.child != null) {
  depth=depth+1;
  p=p.child;
Now do a non-recursive pre-order traversal with the aid of a stack s:
Code:
push(root,0);
while (!s.isEmpty()) {
  s.pop(p,d);
  if (p.child == null && d != depth) {
    return(false);
  if (p.sibling != null) {
    push(p.sibling,d);
  if (p.child != null) {
    push(p.child,d+1);
return(true);
I think it's interesting to note that the above pre-order traversal is exactly the same as a level order traversal except that a stack is used instead of a queue.
It's one traversal that is effectively pre-order.
But we can "do something" in the order we want. (Thinking)
The algorithm is:
Code:
traverseTree(node)
    if node == NULL
        return
    Do something in pre-order
    traverseTree(node->left)
    Do something in in-order
    traverseTree(node->right)
    Do something in post-order
(Wasntme)
The algorithm is:
Code:
traverseTree(node)
    if node == NULL
        return
(Wasntme)
I haven't understood how we can apply the three different forms of tree traversal, in order to check if all the leaves have the same depth.. (Sweating)
Could you explain it further to me? :confused:
Let's take a look at the recursive algorithm again:
Code:
traverseTree(node, depth)
  if node = NULL
    // We're in the non-existing child of a leaf here.
    // This is the place where we can do something with the depth.
    return
  for each child of node
    traverseTree(child, depth + 1)
What might we do when we are in the final case of the recursive function? (Wondering)
I think I detect some confusion on your part. Here's a tree:
Now here's the associated binary tree:
Code:
  if node = NULL
    return
When we have, for example, this tree:
we call the functions [m]traverseTree(a,depth), traverseTree(b,depth+1), traverseTree(e,depth+2), traverseTree(f,depth+3), traverseTree(h,depth+4), traverseTree(i,depth+5)[/m], right? But.. what do we do after the command [m] return; [/m] , that is executed at the function [m]traverseTree(i,depth+5)[/m]? (Worried)
Right. (Smile)
And btw, the depth is initially 0, so the initial call is actually [m]traverseTree(a, 0)[/m]. (Nerd)The first time we get to the [m]return[/m], we need to register the depth.
Every other time, we need to check if the depth is the same as the one we previously registered. (Thinking)
I like Serena said:
Right. (Smile)
Now, I noticed that [m] e [/m] has no children, [m]f[/m] is a sibling of [m] e [/m].
No. [m]f[/m] is a child of [m]e[/m].
It's only that you've drawn them horizontally next to each other. (Mmm)
So, do we have to initialize an other variable for the next leaf? :confused:
But.. we don't know how many there are, right? (Thinking)
I don't understand your questions. (Doh)
  • #31
I haven't undestood how we could do this, when we don't know how many leaves there are? (Worried)
  • #32
For what would we need to know how many leaves there are? (Wondering)
When we traverse the tree, at some point we'll get to a leaf for the first time.
At that time, we can register its depth.
Then we continue traversing the tree.
Whenever we get to a leaf again, we'll check if its depth is the same as the one we registered before. (Thinking)
  • #33
Is it maybe like that? (Thinking)
Code:
depth=0;
traverseTree(node)
  int k;
  if node = NULL
    if (k!=depth) return failure
    return
  depth=0
    depth++
    traverseTree(child)
  k=depth
  return success
  • #34
evinda said:
Code:
1. depth=0;
2. traverseTree(node)
3.   int k;
4.   if node = NULL
5.     if (k!=depth) return failure
6.     return
7.   depth=0
8.   for each child of node
9.     depth++
10.    traverseTree(child)
11.  k=depth
12.  return success
Isn't [m]k[/m] uninitialized when we get to line 5?
That would lead to chaos and madness. (Worried)Setting it to zero in line 7, would make it zero even if we've descended into the tree.
That can't be right! (Sweating)Line 9 is the only line where depth is incremented, and it is never decremented.
That should cause problems. (Doh)Line 11 is setting [m]k[/m], but after that it is never used... (Wasntme)
  • #35
Do we have to use a new variable $k$ or could we also do it in an other way? (Thinking)
  • #36
What do you want to use [m]k[/m] for? (Wondering)
Its name doesn't say anything about its purpose, and as it is currently used, it doesn't seem to do anything useful. :confused:
  • #37
How could we compare the depth of the first leaf with the depth of the second one? :confused:
  • #38
I'm thinking with something like this:
Code:
1. currentDepth=0;
2. treeDepth = 0;
3. traverseTree(node)
4.   if node = NULL
5.     if (treeDepth = 0)
6.       treeDepth = currentDepth;
7.     else if (treeDepth != currentDepth)
8.       return failure
9      else
10.      return success
11. for each child of node
12.    currentDepth++
13.    result = traverseTree(child)
14.    currentDepth--
15.    if result is failure
16.      return failure
17.  return success
(Wasntme)
  • #39
Code:
1. currentDepth=0;
2. treeDepth = 0;
4.   if node = NULL
8.       return failure
9      else
10.      return success
12.    currentDepth++
14.    currentDepth--
16.      return failure
17.  return success
(Wasntme)
Applying the above algorithm at this tree :
I got the following:
currentDepth=0
treeDepth=0
traverseTree(a)
currentDepth=1
result=traverse(b)
currentDepth=2
result=traverseTree(e)
currentDepth=3
result=traverseTreef)
currentDepth=4
result=traverse(h)
currentDepth=5
result=traverseTree(i)
currentDepth=6
result=TraverseTree(NULL)
treeDepth=6
But, then result doesn't get any value.. (Worried)
At the case when [m]treeDepth=0[/m], do we have to return success? (Thinking)
  • #40
Well spotted! I forgot that one. (Blush)
  • #41
So, if we want to trace the algorithm, I tried the following:
Is it right? If so, how could we continue? (Sweating)
  • #42
That looks right, although I think the success should be at depth 6.
At that point, we store the currentDepth in treeDepth.
And then we go back up, and then down into the next child.
Or rather, we keep backing up, until we can go down again. (Wasntme)
  • #43
So, are these commands executed then?
[m] currentDepth++; [/m]
and
[m] result=traverseTree(c) [/m]
Or am I wrong?
Doesn't [m]currentDepth[/m] count the sum of the depths of the leaves? (Thinking)
  • #44
and
Or am I wrong?
I don't understand your question.
Perhaps I'm missing the context. (Thinking)
The variable [m]currentDepth[/m] is supposed to track the current depth of any node in the tree.
If it does anything else, there is a mistake in the program.
So no, I don't think it counts the sum of the depths of the leaves. (Nerd)
  • #45
Do we have to declare then maybe the variable [m]currentDepth[/m] inside the algorithm and not outside? (Thinking)
  • #46
That would be better from the perspective of good programming practice. (Smile)
It does mean that it should be passed as a parameter to the recursive function. (Thinking)
  • #47
I meant something else... (Shake)
When we declare [m] currentDepth [/m] as a global variable, it will increase at the whole function, independent from the node we are looking at in order to check if it is a leaf.
So, it won't track the current depth of any node in the tree, but the sum of depths..
Or am I wrong? (Worried)
  • #48
It will track the current depth, if we increment it whenever we make a recursive call, and decrement it right after that call returns. (Nerd)
  • #49
Oh yes, you are right! (Nod)
At the beginning, we get that [m]TreeDepth=6[/m], but shouldn't it be [m]TreeDepth=5[/m] ? Or am I wrong? (Thinking)
Also, when we execute [m] traverse(j) [/m] and look at the child [m] k [/m] of [m]j[/m], the command [m] return failure; [/m] is executed.
Does this mean that the algorithm terminates and we don't look at the other child of [m] j [/m] and also we don't go back to the recursive calls? (Thinking)
  • #50
I have lost the context, which is probably somewhere far back in this thread. (Blush)
What is the context? (Wondering)
