You are a tourist on space odyssey; at what altitude above the surface
To determine the altitude at which a tourist's weight is half of their weight on Earth's surface, the gravitational force equation Fg = GMm/r^2 is used. The discussion clarifies that the relevant variable to adjust is the distance from the center of the Earth, R, which includes Earth's radius plus the altitude above the surface. The gravitational constant G and Earth's mass M remain unchanged. The conversation emphasizes that the altitude must be calculated in terms of Earth's radius, rE, and highlights the importance of distinguishing between actual and apparent weight in different gravitational contexts. Ultimately, the solution involves finding the correct altitude where gravitational force is halved.
jasonbans
You are a tourist on space odyssey; at what altitude above the surface of Earth will your weight be one-half your weight on the surface? express your answer as a mutiple of Earth's radius rE
Fg= GMm/r^2
not sure how to do it
Fg= GMm/r^2
Do you mean your actual weight or your apparent weight? Remember the apparent weight of people on the space station is zero as they are in free fall, but their actual weight is around 90% of their weight on Earth - because there g ~ 8.9 rather than the 9.8 on the surface.
actual weight
jasonbans said:
actual weight
Look at your formula and consider what change can be made to halve the force.
I don't think you can change G - is is after all the Universal Gravitational Constant.
M won't alter - mass of the Earth
You could halve m if you put the passenger on a diet, but I don't think that is feasible.
Doesn't leave much else - and remember R is the distance from the centre of the Earth, so we are already one Earth radius away when standing on the surface.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
