Young's double slit: why fringes gets dimmer and inconsistent?
The discussion revolves around the behavior of bright fringes in Young's double slit experiment, specifically addressing why the fringes become dimmer as one moves away from the central maximum and why the observed fringes may not align consistently with the theoretical formula for double slit interference.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests that the dimming of the fringes is due to the decrease in amplitude from each single slit as one moves away from the center, questioning if this explanation is too simplistic.
  • Another participant points out that the formula for double slit interference (dsin(theta) = m*λ) is valid primarily under the small angle approximation, implying that larger angles lead to discrepancies in the observed fringe positions.
  • A later reply mentions that the intensity pattern for a single slit modulates the double slit pattern, indicating that the interference maxima are narrower than the diffraction maxima due to the relative sizes of the slits and their separation.
Participants express differing levels of understanding regarding the dimming of fringes and the application of the double slit formula, indicating that multiple competing views remain and the discussion is not resolved.
The discussion highlights potential limitations in understanding related to the assumptions of the small angle approximation and the dependence on the definitions of intensity patterns in single and double slit experiments.
Individuals interested in wave interference, optics, and the principles underlying Young's double slit experiment may find this discussion relevant.
Simon George
Hi all!
In Young's double slit experiment, there are two things I cannot explain. Any help is appreciated!
The first one is why the bright fringes get dimmer as you get further from the central/brightest spot. My theory, after looking in the two books I have, is that each single slit decreases the amplitude the further it goes from the center. I find this explanation kind of "too easy" and simple. Is that just it? and does that relate to any equation of intensity for double slit?
The second one is why the bright fringes get inconsistent with the formula for double slit (dsin(theta)=m*walength) as we get further form the center. For that, I have absolutely no idea and can't seem to find the answer anywhere.
Thank you!
Science news on Phys.org
Search about double slit interference in khan academy.They have explained it well very clearly
Thank you! Still don't get it why it gets dimmer. It seems vague
That's basically it. Do a Google search for "single slit diffraction" and you'll find many graphs of the intensity pattern for a single slit. For double slits (try searching for "double slit diffraction") the basic two-slit interference pattern "modulates" the single-slit pattern by "chopping it up" into narrower maxima. The "interference maxima" are narrower than the "diffraction maxima" because the distance between the slits is (normally) much larger than the width of each slit.
  • · Replies 34 ·
  • · Replies 30 ·
21K
10K
  • · Replies 20 ·
18K
