Youngs Modulus in case of thermal expansion
Young's modulus (E) is defined as stress divided by strain, but in cases of free thermal expansion, there are no stresses, leading to the misconception that E could be zero. However, E is a material property that cannot be zero. The total strain in a material includes elastic, thermal, and plastic strains, and in free expansion, only thermal strain is present. When a body is constrained and heated, thermal and elastic strains become equal and opposite, resulting in stress. The relationship between stress, strain, and temperature change must be considered, indicating that E remains a relevant property even when stresses are not present.
raja24
We know that youngs modulus(E) is stress/strain. In case of free body thermal expansion, if the material is allowed to expand and contract freely, than there are no stresses in the body. The body has only strains.
That means the stresses are zero in case of free expansion. So in this case youngs modulus E will also be zero because E=stress/strain. But E cannot be zero since it is a material property...so what will be the value of E when stresses are zero? Does E has a value?
That is not quite right. E = stress / elastic strain. There are other things that can create strain, including thermal expansion.
The change of shape or size of the body (the total strain) = elastic strain + thermal strain + plastic strain + etc.
In your example there is a thermal strain, and the elastic strain = 0.
If you fixed the body so it can not expand, and heat it, the total strain = 0, the elastic strain and thermal strain are equal and opposite, and there will stress = E times the elastic strain. (This is sometimes called the "thermal stress", which may be confusing you)
Dear AlephZero, Thanks for the reply...You said that stress=E times strain, this is when the body is fixed.
But if the body has free expansion i.e, its is allowed to expand and contract freely...then there will be no stresses in the body, it has only strains (all kinds). Then in this case according to stress-strain relationship...E=stress/strain...since stresses are zero in free expansion...E=0/strain and E will be zero too...
But this cannot be possible because E cannot be zero since it is a material property...so how is this justified...I hope you got my question
The equation you're using assumes constant temperature.* If the temperature can change, then the strain is \epsilon=\sigma/E+\alpha\Delta T.
*Along with uniaxial elastic loading and negligible lateral stresses.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
