How Does Zee Simplify Integrals in QFT Derivations?
  • Thread starter Thread starter Cadaei
    Derivation Qft
Cadaei
On page 12 of Zee's QFT in a nutshell, he rewrites an integral from dirac notation to a mixture of schrodinger/dirac
My question is, since
, what happened to the integrals, and shouldn't there be four wave functions instead of two?
I tried writing out the integrals explicitly, thinking maybe theyre integrated out with a delta function or something, but with no luck - I don't see how to get to psi(q_f).
Any help would be appreciated.
Let me rewrite the matrix element as \langle \Psi_{F}| e^{- i H T} | \Psi_{I} \rangle . Now insert the completeness relations \int d X_{a} \ | X_{a} \rangle \langle X_{a} | = 1 , \ \ \mbox{for} \ \ a = I , F . You find \langle \Psi_{F}| e^{- i H T} | \Psi_{I} \rangle = \int d X_{F} d X_{I} \langle \Psi_{F}| X_{F} \rangle \langle X_{F}| e^{ - i H T} | X_{I} \rangle \langle X_{I} | \Psi_{I} \rangle . Okay, now use the definitions of the wavefunctions \Psi_{I} ( X_{I} ) = \langle X_{I} | \Psi_{I} \rangle , \ \ \Psi^{*}_{F}(X_{F}) = \langle \Psi_{F} | X_{F} \rangle .
I think I'm missing something extremely simple here... why is dotting ⟨X_I| into |psi_i⟩ the same as evaluating psi_I at X_I?
And yes, you need to know the difference between state vector |\Psi \rangle and its coordinate representation, i.e. wave-function \Psi ( x). Almost all textbooks explain the Bra-Ket notations and their connection to “wave-functions”.
You seem to have no problem with \langle \Phi | \Psi \rangle = \int dx \ \Phi^{*} (x) \Psi (x) . \ \ \ \ (A) Okay, let us work on the left-hand side by inserting the completeness relation 1=\int dx |x\rangle \langle x|:
\langle \Phi | \Psi \rangle = \langle \Phi | ( \int dx |x \rangle \langle x | ) | \Psi \rangle = \int dx \ \langle \Phi | x \rangle \langle x | \Psi \rangle .
Now, if you compare the RHS of this equation with the RHS of Eq(A), what would you get?
Similar state of affair exists in elementary vector algebra. You know how to expand a vector |\vec{V}\rangle in terms of some orthogonal unit-vectors | e_{i}\rangle |\vec{V}\rangle = \sum_{i} V_{i} \ | e_{i} \rangle .\ \ \ \ (1) You also know the ortho-normality condition \langle e_{i} | e_{j} \rangle = \delta_{ij} . \ \ \ \ \ \ \ (2) You should also know how to calculate the components of the vector from V_{i} = \langle e_{i} | \vec{V}\rangle . \ \ \ \ \ \ \ (3) You can now substitute (3) in (1) to obtain another familiar equation in vector algebra | \vec{V} \rangle = \sum_{i} | e_{i}\rangle \langle e_{i} | \vec{V} \rangle . \ \ \ \ \ \ (4) This leads to the completeness relation for the unit vectors \sum_{i} | e_{i} \rangle \langle e_{i}\rangle = 1 . \ \ \ \ \ \ (5) And finally, you know the scalar product \langle \vec{V}| \vec{U} \rangle = \sum_{i} V^{t}_{i} U_{i} .\ \ \ \ \ (6) Now, imagine the vector space to be an infinite-dimensional complex vector space spanned by un-countable infinity of ortho-normal functions (vectors) |e(x)\rangle \equiv | x \rangle, i.e. just pass to the continuous limits i \to x , \ \ \ | e_{i}\rangle \to | x \rangle , \ \ \sum_{i} \to \int dx , and V_{i} \to V(x), \ \ \ V^{t}_{i} \to V^{*}(x) . So, we can translate Eq(1)-Eq(6) into the continuous language as follow \mbox{Eq(1)} \to \ \ \ | V \rangle = \int dx \ V(x) \ | x \rangle , \mbox{Eq(2)} \to \ \ \ \langle x | y \rangle = \delta (x - y) . \mbox{Eq(3)} \to \ \ \ V(x) = \langle x | V \rangle , which is what you were asking about \Psi (x) = \langle x | \Psi \rangle. \mbox{Eq(4)} \to \ \ \ | V \rangle = \int dx \ | x \rangle \langle x | V \rangle . \mbox{Eq(5)} \to \ \ \ \int dx \ | x \rangle \langle x | = 1 . And finally the equation you know \mbox{Eq(6)} \to \ \ \langle V | U \rangle = \int dx \ V^{*}(x) U(x) .
samalkhaiat said:
Then why are you reading QFT text?
Thank you for your help, I understand now.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
