Zero Matrix Nilpotency: Defined & Explained
  • Thread starter Thread starter *best&sweetest*
*best&sweetest*
Can a zero matrix be considered as nilpotent matrix?
Zero matrix raised to any positive power is zero matrix, so can it be considered nilpotent (with index of nilpotency being 1)? I have read the definition of the nilpotent matrix and it doesn't that say that a matrix has to different from 0, but I'm still confused...
sure, you can say that the zero matrix is nilpotent, but that would be considered the trivial case. i.e., if you are asked to find a nilpotent matrix satisfying some properties, using the zero matrix will probably not get you credit for solving the question.
Why are you confused? Another characterization of "nilpotent" is that a matrix is nilpotent if and only if its eigenvalues are all 0. That is certainly true of the 0 matrix. The 0 matrix is definitely nilpotent.
Thank you!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
