Why Does 0/0 ≠ 0 When o x o = 0?
  • Thread starter Thread starter lakshmi
    Zero
The discussion centers on the confusion surrounding the expression 0/0 and its relation to multiplication. Participants argue that since any number multiplied by 0 equals 0, it seems logical to suggest that 0/0 could equal any number, such as 3 or π. However, the consensus is that 0/0 is undefined in arithmetic because assigning it a value leads to contradictions and inconsistencies. The conversation highlights the importance of adhering to mathematical rules to avoid confusion. Ultimately, 0/0 remains an indeterminate form that cannot be resolved within standard arithmetic.
lakshmi
if o multiplied by o=0
then why 0/0 is not equal to 0
Mathematics news on Phys.org
Well, 0 \times 3 = 0 so shouldn't \frac{0}{0}=3?
I know, 0 \times \pi = 0 so \frac{0}{0}=\pi.
The problem is that \frac{0}{0} doesn't work with the existing rules for arithmetic. Picking some value only leads to problems.
:smile: :smile: :smile:
excellent humour NateTG :wink:
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
