How Does the Limit of (1 + x/n)^n as n Approaches Infinity Equal e^x?
  • Thread starter Thread starter island-boy
    Proof
The discussion revolves around the limit of the expression (1 + x/n)^n as n approaches infinity, specifically exploring its equivalence to e^x. Participants are examining the mathematical foundations and proofs related to this limit, which falls under the subject area of calculus and limits.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are discussing various approaches to prove the limit, including the use of the derivative of e^x, the Binomial theorem, and Taylor series expansions. Some question the rigor of certain steps and the validity of limits used in the proofs.
The discussion is active, with participants providing hints and suggestions for alternative methods. Some have offered proofs using Taylor expansions and the Binomial theorem, while others have raised concerns about the rigor of certain arguments and the correctness of limits applied. There is no explicit consensus on the proofs presented.
Participants are navigating through assumptions related to the definitions of e^x and the conditions under which the limits are evaluated. There are indications of confusion regarding the application of limits in certain expressions, as well as the need for more rigorous justification in some arguments.
island-boy
hello, I need the proof to show that:
[tex] e^x = \lim_{n\rightarrow\infty} (1+x/n)^n[/tex]
Here's what I was able to come up with so far:
since the derivative of [tex]e^x[/tex] is also [tex]e^x[/tex],
then let f(x) = [tex]e^x[/tex]
thus:
D(f(x)) = [tex]\lim_{n\rightarrow\infty} \frac{f(x+h) - f(x)}{h} = \lim_{n\rightarrow\infty} \frac{e^{x+h} - e^x}{h} = e^x\lim_{n\rightarrow\infty} \frac{e^h - 1}{h}[/tex]
so for the derivative of [tex]e^x[/tex] to equal itself,
[tex]\lim_{n\rightarrow\infty} \frac{e^h - 1}{h} = 1[/tex]
so for small values of h, we can write:
[tex]e^h - 1 = h[/tex]
and so
[tex]e = (1+h)^{1/h}[/tex]
Replacing h by 1/n, we get:
[tex]e = (1 + 1/n)^n[/tex]
As n gets larger and approaches infinity, we get:
[tex]e = \lim_{n\rightarrow\infty} (1+1/n)^n[/tex]
so, how do I get:
Also, is it true that:
[tex](1+x/n)^n \leq e^x[/tex] and
[tex](1-x/n)^n \leq e^{-x}[/tex] for every natural n and every x element of X?
How can I prove this?
thanks!
thanks!
Have you tried the Binomial theorem ?
I would've taken the expression for e and raised both sides to the x power.
You really ought to do this more rigorously...
P.S. many of the limits in your limits are wrong.
As a hint, set 1/u=x/n, and re-express in terms of u and x.
Hurkyl said:
I would've taken the expression for e and raised both sides to the x power.You really ought to do this more rigorously...
which one of the limits are wrong?
I was able to prove that:
[tex](1 + x/n)^n \leq e^x[/tex] and [tex](1 - x/n)^n \leq e^{-x}[/tex]
Using the Taylor expansion for [tex]e^x[/tex], I got
[tex]e^x = 1 + x + \frac{x^2}{2!} + \frac{x^3}{3!} + ...[/tex]
which means
[tex]e^x \geq 1 + x[/tex]
subtituting x by x/n, I get
[tex]e^{x/n} \geq 1 + x/n[/tex]
thus
[tex]e^{(x/n)n} \geq (1 + x/n)^n[/tex]
simplifying, I get:
[tex]e^x \geq (1 + x/n)^n[/tex]
Similarly I used the Taylor Expnansion to prove that
since [tex]e^x = 1 + x + \frac{x^2}{2!} + \frac{x^3}{3!} +...[/tex]
and using binomial theorem for [tex]\lim_{n\rightarrow\infty} (1+x/n)^n[/tex]
I got:
[tex]\lim_{n\rightarrow\infty}1^n + \lim_{n\rightarrow\infty} x + \lim_{n\rightarrow\infty} \frac{n(n-1)(x^2)}{(n^2)(2!)} + \lim_{n\rightarrow\infty} \frac{n(n-1)(n-2)(x^3)}{(n^3)(3!)} + \lim_{n\rightarrow\infty} \frac{n(n-1)(n-2)(n-3)(x^4)}{(n^4)(4!)} + ...<br /> <br /> = 1 + x + \frac{x^2}{2!} + \frac{x^3}{3!} +...<br /> <br /> =e^x[/tex]
these correct?
You've used n-->infinity in expressions that don't even have an n in them! (You meant h-->0)
See this thread posts # 3 and 12.
I take it that your definition for [tex]e^x[/tex] is the Taylor series about x=0, viz.
[tex]e^x=\sum_{k=0}^{\infty}\frac{x^k}{k!}[/tex]
Essentially, this
benorin said:
That [tex]\lim_{n\rightarrow\infty} (1+\frac{x}{n})^n = e^x[/tex] may be proven as follows:
by the binomial theorem,
[tex](1+\frac{x}{n})^n = \sum_{k=0}^{n} \frac{n!}{k!(n-k)!}\left( \frac{x}{n}\right) ^{k} = \sum_{k=0}^{n} \frac{n!}{(n-k)!}\frac{1}{n^{k}} \frac{x^k}{k!}\rightarrow \sum_{k=0}^{\infty} \frac{x^k}{k!}=:e^{x}\mbox{ as }n\rightarrow\infty[/tex]
since [tex]\frac{n!}{(n-k)!}\frac{1}{n^{k}} \rightarrow 1 \mbox{ as }n\rightarrow\infty[/tex]
although there are some uniform convergence issues to be handled when taking the limit of the above sum...
and this,
benorin said:
This is not rigorous, but it works...
[tex]\frac{n!}{(n-k)!} = \frac{n(n-1)(n-2)\cdots (n-(k-1))(n-k)!}{(n-k)!} =n(n-1)(n-2)\cdots (n-(k-1))[/tex]
counting the number of terms in the above product: it goes n-0 through n-(k-1) so there are (k-1)-0+1 = k terms so we know that the leading term will be nk when the product is expanded, and hence
[tex]\frac{n!}{(n-k)!} = n^k + \mbox{ some polynomial of degree k-1 in }n[/tex]
or rather
  • · Replies 20 ·
