How Do You Calculate Impedance for Series and Parallel RLC Circuits?
In summary: From there you can find the magnitude of the impedance, |Z|, and the phase angle of the impedance, phi. The only slightly tricky part is that the phase angle is NOT the same as the phase angle of any of the components. The formula for the phase angle is tan(phi) = (Imag part of Y)/(Real part of Y). You need to be careful when you enter this into your calculator, since you need to take the inverse tangent of the ratio of the imaginary part to the real part. Most calculators have a "complex" mode that allows you to enter complex numbers, and then use the arrow keys to select the "Imaginary part" or "Real part" function to extract
physicsphy
I come across the impedance for an inductor an capacitor combined is Z = XL - XC, for a resistor and capacitor in series is Z = sqrt(R^2 + XC^2) and how do you obtain a formula for a combination of a capacitor, an inductor and a resistor in series and in parallel?
in series, Z = R + wL + 1/(w*L)
in parallel Z = (R*wL)(1/wL)/(R+wL)+(1/wC)
Hi physicsphy, Welcome to Physics Forums.
Strictly speaking, XL and XC are called reactances, and X = XL - XC is the total reactance for the series combination of inductor L and capacitor C.
Impedance is the 'big brother' of resistance, and and is a representation of resistance and reactance together in the form of complex numbers, thus Z = R + jX. Using impedance you can apply all the formulas you normally would for resistances, only one uses complex number math. For the basic components then,
##ZR = R##
##ZL = jωL##
##ZC = 1/(jωC) = -j/(ωC)##
As you can see, the reactances of L and C components are simply the values of the imaginary components without the "j" constants.
You can treat ZR, ZL, and ZC just as you would resistances when combining them. So impedances in series simply add: R + ZL + ZC, while impedances in parallel are combined using the reciprocal of the sum of reciprocals method:
##Z = \frac{1}{1/R + 1/ZL + 1/ZC} ##
The magnitude of the impedance is found by summing the real and imaginary components in quadrature (square root of the sum of the squares, just like you would for vector components). You should be able to determine that for the series connection, the magnitude of the impedance turns out to be identical to your reactance method, namely
##|Z| = \sqrt{R^2 + (XL - XC)^2}##
For doing the parallel case it is often easier to deal with the reciprocals of the impedances (Y = 1/Z) for each component. These are called admittances, and are the complex version of conductance (G = 1/R). You can simply add parallel admittances as you did for series impedances. Pay attention to the signs assigned to the "reactance" version of admittances, since taking the reciprocal of a complex number reverses the sign of the complex component.
Once you have the net admittance, Y, you can find the impedance using Z = 1/Y.
1. What is the formula for impedance?
The formula for impedance is Z = R + jX, where Z is the total impedance, R is the resistance, and jX is the reactance.
2. How is impedance different from resistance?
Impedance takes into account both resistance and reactance, while resistance only considers the resistance of a circuit element. Impedance also takes into account the phase relationship between voltage and current, while resistance does not.
3. What is the unit of measurement for impedance?
The unit of measurement for impedance is ohms (Ω).
4. How is impedance calculated in a series circuit?
In a series circuit, the total impedance is equal to the sum of the individual impedances. This can be calculated using the formula Z = Z1 + Z2 + ... + Zn, where Z1 to Zn are the individual impedances of the circuit elements.
5. Can the formula for impedance be used in both AC and DC circuits?
Yes, the formula for impedance can be used in both AC and DC circuits. However, in DC circuits, the reactance component is equal to zero, so the formula simplifies to Z = R.
9K
  • Classical Physics
