feynman1
- 435
- 29
as title
Aren't those identical in this application? If you want to use 'intuition', that implies you have some, perhaps unconscious, idea of what is going on. The typical way to gain this 'intuition' is by examining many instances of a phenomina and drawing conclusions as to how various factors affect the result.feynman1 said:how to draw those lines by hand or intuition?
To draw stress lines without calculation, you can use the graphical method. This involves drawing a grid on the surface of the object and marking the known stress points. Then, using a ruler or protractor, you can draw lines connecting the stress points to create a stress diagram. This method is less accurate than calculation, but it can provide a visual representation of the stress distribution on the object.
Drawing stress lines helps to visualize the distribution of stress on an object. This can be useful in identifying areas of high stress concentration, determining the direction of stress, and understanding the overall stress distribution on the object.
Yes, you can use any type of grid for drawing stress lines. However, it is recommended to use a square or rectangular grid to ensure accuracy in the stress diagram.
No, you do not need to know the exact stress values to draw stress lines. As long as you have at least two known stress points, you can use the graphical method to draw stress lines without calculation.
Yes, there are limitations to drawing stress lines without calculation. This method is less accurate than calculation and may not be suitable for complex stress distributions. It is also important to note that the stress lines drawn may not represent the actual stress values on the object, but rather the relative stress distribution.
