mech-eng
- 828
- 13
- TL;DR Summary
- I am trying to link files
Is there anyway that pdf, html or any other type of files can be linked into a txt file? That is, I would like to click to a link in a txt that will open another file.
Yes, simply type the URL in the file e.g.mech-eng said:Is there anyway that pdf, html or any other type of files can be linked into a txt file?
https://www.physicsforums.com/threads/linking-files-into-a-txt-file.996247/#post-6419210
It is not files that follow links, it is the application you use to read the file. Are you asking 'is there an application that will follow links in txt files'? Some advanced text editors (like VS Code already mentioned) can do this.mech-eng said:That is, I would like to click to a link in a txt that will open another file.
Linking files into a txt file means that you are creating a connection between the txt file and other files. This allows for easy access to the linked files within the txt file.
To link files into a txt file, you can use a text editor or coding software to insert the file path or URL of the linked files into the txt file. You can also use HTML <a>
tags to create clickable links to the files within the txt file.
Yes, you can link any type of file into a txt file as long as the file is compatible with the software or program used to open the txt file. This includes images, documents, videos, and more.
Linking files into a txt file allows for easier organization and access to related files. It also makes it easier to share or transfer multiple files at once and can save storage space by not having to duplicate files in multiple locations.
No, linking files into a txt file does not allow for direct editing of the linked files. You will need to open the linked file separately in its respective software or program in order to make changes to it.
