Moopcan
- 1
Set up the volume integral of x^2 + y^2 + z^2 between z=sqrt(1-x^2-y^2) and z=x^2
Cartesian differential volume element, spherical differential volume element
In class I've been told when doing triple integrals to try and find an extrusion so that I can reduce the problem to a double integral. I don't see how I can do that in this case though because when looking from the top,. I have an idea of what the problem looks like, it's half a sphere being cut out by a parabolic sheet.
If I try to look on the x-z plane, I can start bounding y(as in the inner integral) between -sqrt(1-x^2-z^2) and sqrt(1-x^2-z^2). But if I try to bound z, I have z < sqrt(1-x^2-y^2), which depends on y and I don't think that really makes sense...
I considered going to spherical at this point because every way I tried to bound it in cartesian led to integration bounds being in terms of previously eliminated variables.
So in spherical, the sphere half becomes r=1 and the parabola sheet becomes r=cot(phi)sec(theta).
theta is between 0 and 2Pi. It's half of a sphere, so phi is between 0 and pi/2. The original function goes to r^2 in spherical and r is between cot(phi)sec(theta) and r=1. The integrand is r^4 * sin(phi) and the order of integration is dr dtheta dphi
I wasn't sure of this so I put it into MathCAD to see if it spat something out that made sense and...it sat there and didn't stop calculating. Which tells me that I've done something wrong.
I get the feeling that something is wrong with my radius limit. And that I'm missing something in cartesian.
I just randomly had another idea. Could I do inner as x^2 < z < sqrt(1-x^2-y^2), intersect the two to yield x^4 = 1 - x^2 - y^2 which when solving for x, yields x^2 = -1/2 + sqrt(5-4*y^2), which gives a really disgusting expression for x in terms of y. Could I use -disgusting expression < x < disgusting expression as my middle and -1<y<1 as the outer?
