Is there any work done by static friction when accelerating a car?
The discussion revolves around the question of whether static friction does any work when a car accelerates. Participants explore the role of friction in the context of driving and walking, examining the conditions under which work is defined and the implications of different reference frames.
  • Some participants assert that under the "no slip" condition, the force of friction from the ground does no work, as the contact patch does not move horizontally.
  • Others argue that while the ground does not perform work, the friction force enables the car to gain kinetic energy by converting energy from the engine.
  • A participant introduces the concept of a closed system, suggesting that the momentum is conserved and the work done by friction is offset by the energy from the fuel consumed by the engine.
  • There is a discussion about the distinction between "real work" and "center of mass work," with some participants emphasizing that the relevant motion for work done depends on the reference frame used.
  • Some participants mention that different physics textbooks define work differently, which may lead to varying interpretations of the role of friction.
  • A comparison is made between the frictional forces in a car and the forces acting on a rocket in space, suggesting similarities in how work is performed in both scenarios.
Participants express differing views on whether static friction does work and how to define work in this context. There is no consensus, as multiple competing interpretations and models are presented throughout the discussion.
Limitations include the dependence on definitions of work, the assumptions made regarding reference frames, and the varying interpretations of friction's role in energy transfer.
  • #151
Dale said:
The dilemma lies in conflating the change in momentum with a change in energy. Momentum and energy are closely related, but they are not the same thing. You can have a force which transfers momentum and does not transfer energy, which is the case with the car.
Well said. Our assumptions about immovable anchors in experiments is well justified, Momentum is still conserved and no Energy is 'lost'.
  • #152
Dale said:
But without that extra information you cannot determine the change in the energy of the system.
Yes, understood. Which is why I was careful not to include "energy" in the list of knowable things, given the more limited information.
  • #153
The extra information could be determined. Force exerted onto the vehicle = mass of vehicle · acceleration of vehicle. Assuming a flat road, you have a force exerted onto a vehicle and the current velocity of the vehicle. My premise is that the power = force exerted on vehicle times velocity of the vehicle. The acceleration of the vehicle is linear (still assuming a flat road). The angular acceleration of the entire drive train is due to the torque of the engine being slightly greater than the opposing torque related to the force exerted at the contact patch times the effective radius, so the "power" related to the force exerted onto the vehicle is only responsible for the energy change related to the linear acceleration.
  • #154
This premise is adequately demonstrated to be false above many many times.
  • #155
Ah, good point. I didn’t pick up on that the first time.
  • #156
The force is not the missing information. The velocity of the material at the contact point is the missing information.
  • #157
The velocity of the material at the contact point is zero, but's rolling motion and the tire moves at the same speed as the vehicle. If power was force times velocity of the materials, power would be zero, and over time work would be zero, but the work is known to be non-zero since the vehicle accelerates coexistent with an increase in kinetic energy.
Linear acceleration of vehicle is force / vehicle mass. So it's still my premise that the change in kinetic energy related to the linear acceleration is accounted for by the force exerted onto the vehicle times the velocity of the vehicle.
  • #158
You can’t know that if you are treating the car as a black box.
  • #159
What in the world does "accounted for" mean?
Because of the mechanical system everyone agrees that the two numbers are equal.
There is nothing more interesting than that here...
  • #160
I posted a question at stack exchange physics forum, initially about the contact patch issue which I later corrected, but the response I received is similar to what I've seen elsewhere:
"The road is, in fact, doing work on the car to propel it forward."
https://physics.stackexchange.com/questions/527495/527502#527502
I'm still looking for the thread about a small planet and car where the mass of the planet wasn't so much greater than the car that the acceleration (mostly angular) of the planet couldn't be ignored in calculating the conversion of potential energy into kinetic energy of the closed system.
  • #161
The response is incorrect. If the road is doing work on the car then why doesn’t the energy increase?
It is pretty funny that you have scores of correct responses here, but because that one incorrect response is what you wanted to hear you immediately grab onto it. You appear to be immune to any logical arguments and simply set on sticking with your incorrect notion regardless.
  • #162
The kinetic energy increases due to acceleration, the potential energy decreases due to consumption of the energy source (fuel or battery). If the energy comes from an external source, such as the Sun, then the vehicle experiences a net gain in energy, the solar energy received on the solar panel is eventually converted into kinetic energy of the vehicle, using the road to supply the external force that accelerates the vehicle.
  • #163
Therefore the rate of change of energy for the car is zero: no power.
That is not in question. The road does supply the force that changes the momentum. The energy does not change so the road cannot supply any power.
  • #164
At this point the OP is long gone and the subject has been beaten to death. @Dale's final post sums up the basic points so this seems like a good time to close the thread.
  • · Replies 73 ·
11K
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 29 ·
  • · Replies 59 ·
