Gravitational wave propagation in GR - follow up
cianfa72
TL;DR
About the analysis of LIGO measurements in TT gauge coordinates
I'd like to consider again what discussed in this Gravitational wave propagation in GR.
The analysis of GWs' LIGO measurements is performed in Transverse-Traceless (TT) Gauge coordinates. Basically, in the linearized gravity model, the metric tensor field ##g_{ab}## is assumed to be in the form ##g_{ab} = \eta_{ab} + h_{ab}## (note the use of abstract index notation).
As far as I can tell, the TT gauge defines a chart in which the EFEs in vacuum transform into the wave equation ##\Box \bar h_{ab}## for the tensor field ##\bar h_{ab}##. The latter is defined as $$\bar h_{ab} = h_{ab} - \frac {1} {2} \eta_{ab}h^c_c$$ So far so good.
Matematically, the wave equation above has for instance plane wave solutions. They are wave solutions in TT gauge coordinates.
As far as I understood, in LIGO measurement analysis, the arms of the interferometer are taken as "at rest" in TT coordinates (i.e. the worldlines of the arm's worldsheets have constant spacelike coordinates and varying timelike coordiante).
My questions: Why the above holds true and is the solution in wave form an invariant fact ?
In the TT gauge (coordinates), the metric stain, ##h_{ab}##, only has spatial components, ##h_{xx}, h_{xy},\cdots##, are non-zero and are time dependent. One way to view LIGO is in terms of the proper lengths of the interferometer arms. These lengths are time dependent as the wave passes. “At rest” in your post I assume means the spatial locations (coordinate values) of the interferometers mirrors are not time dependent in the TT frame.
cianfa72 said:
TL;DR: About the analysis of LIGO measurements in TT gauge coordinates
My understanding is that the test masses in Ligo essentially follow space-time geodesics (aka are in free fall), ignoring some of the complexities regarding the fact that they need to be suspended against the Earth's gravity. This is done with multiple isolating pendulums. Of course there is still unavoidable noise caused by the suspension system especially at low frequencies.
So what Ligo measures is essentially the change in the separation of test masses following the geodesics. They're not actually freely floating in a vacuum, but the suspension mechanism is designed so that we can treat them as if they were.
This distance measurement is done with what they call a "Fabry Perot" interferometer, which bounces the light back and forth between the mirrors attached to the test masses ~300 times to amplify the phase shift / increase the effective optical path length of the arms.
Are you also interested in the respopnse of the Earth as a whole to the gravitational waves? I gather it's resonant frequency is well below the band Ligo measures, basically if you view the Earth as a distributed spring-mass system, the "spring" parts are pretty weak.
So you can think of the Earth and the test mases as moving in a similar manner as far as Ligo is concerned. The "springiness" of the Earth isn't high enough to affect the motion of the ground much over a gravitational wave cycle in Ligo's bandwidth.
Ok, so the timelike congruence "at rest" in TT gauge coordinates (i.e. the congruence described by timelike worldlines with fixed spacelike TT coordinates) is hypersurface orthogonal even though it isn't stationary. This congruence should be geodesic, so it describes freely-falling masses.
Ok, so such test masses can be taken as free-falling for the purposes of measurements made with LIGO's interferometers.
pervect said:
This distance measurement is done with what they call a "Fabry Perot" interferometer, which bounces the light back and forth between the mirrors attached to the test masses ~300 times to amplify the phase shift /increase the effective optical path length of the arms.
Ok, so in a spacetime diagram we can consider the light back and forth path between the mirrors attached to the free-falling test masses. Of course the proper time along both mirror's worldlines for the round-trip journey of the light beam changes in the presence of a GW wave.
Yes. The ##\Gamma^\mu_{\nu\alpha}## terms in the geodesic equation only sprout space components in the TT gauge. Basically, ##\Gamma^x_{tt}=\Gamma^y_{tt}=\Gamma^z_{tt} = 0##. A point particle at rest in this frame remains at rest as the wave passes because all the ##\frac{dx^\mu}{ds}## terms start and remain 0 as the wave passes. The distance between two point masses, however, does change in time as the wave passes.
I’ve found the TT gauge very useful in visualizing how a Weber bar detector converts GWs into vibrational energy.
Ok, this because for a worldline at rest in TT gauge coordinates, i.e. ##(t, x_0, y_0,z_0)##, the geodesic equation becomes: $$ \frac {d^2x^{\mu}} {ds^2} = - \Gamma^{\mu}_{tt} = 0$$ and ##(t, x_0, y_0,z_0)## indeed solves it.
You mean the spacelike distance between them evaluated on spacelike hypersurfaces of constant coordinate time ##t## (i.e. the path integral along the geodesic of the induced metric connecting the intersections of point masses' worldlines on each of those spacelike hypersurfaces).
Note, however, that the measurements performed by laser interferometers involve the spacetime path taken for the round-trip journey of the light beams.
cianfa72 said:
You mean the spacelike distance between them evaluated on spacelike hypersurfaces of constant coordinate time t (i.e. the path integral along the geodesic of the induced metric connecting the intersections of point masses' worldlines on each of those spacelike hypersurfaces).
I mean proper distance changes with ##s##, the proper time. These are frame independent quantities. In the TT coordinates, ##s=t##.
The actual measurement occurs at the point where the beams from each arm are combined. What’s measured is the time variation of the light intensity caused by the phase difference between the two beams. This phase difference is proportional to the proper length difference of the arms.
ok yes.
Yes. Just to be clear: the metric isn't stationary (in the spacetime region where the GW passes). The proper length of each arm is defined as the length along a spacelike curve orthogonal to the arm's worldsheet (assuming it has only one spatial dimension). So, what you can get from the round-trip journey of light beams is not exactly the arm's proper length (although what is relevant is the phase difference between the two arms of the interferometer).
At this point I find it instructive to consider some numbers. A round trip time for light in a 4km long interferometer is,
\frac{8\times 10 ^3}{3\times 10^8} = 27 us
Gravitational events detected are in 500ms to 1s duration range. Of course the number of light transversals for LIGO is much higher than one because the interferometer finesse (Q value) is quite high. In the end the rate of change of the lengths are much much slower than the light transversal times.
Note that LIGO doesn't measure arm length. It's an interferometer, so what it measures is differences in flight time between the two arms, not the flight times themselves. This gives you the difference in the arm lengths as a function of time, but not the lengths themselves.
Because of the interferometer design, the beam bounces back and forth multiple times, making the effective length (and the storage time) much longer. The web is suggesting the actual storage time is in the 1-3 millisecond range, due to what they call the "Finesse" of the Fabry-Perot interferometer.
Possibly of interest. https://arxiv.org/abs/1409.4648 "Fermi-Normal, optical, and wave-syncrhonus coordinates for spaceetime with a plane gravitational wave".
Why it might be of interest- Fermi Normal coordinates are generally the closest one can come to an inertial frame of reference. There is of course no difficulty with using generalized coordinates if they are more convenient to work withy, and while I haven't read this particular paper, in general Fermi Normal coordinates aren't all that convenient to work with.
Coming back to TT gauge coordinates, the components of the metric tensor field ##g## in that chart are $$g_{\mu \nu} = \eta_{\mu \nu} + h_{\mu \nu}$$ in which ##h_{\mu \nu}## is solution of the wave equation $$\Box h_{\mu \nu} = 0$$ and ##\eta_{\mu \nu}## is diag(-1,1,1,1).
If I recall correctly, a plane wave in the TT gauge propagating along z is,
h_{\mu\nu} = H_+ f(t-z) + H_\times g(t-z)
where ##f## and ##g## are arbitrary functions. The constant polarization matrices are,
H_+ = \left(\begin{array}{cccc}
0 & 0 & 0 & 0 \\
0 & 1 & 0 & 0 \\
0 & 0 & -1 & 0 \\
0 & 0 & 0 & 0
\end{array}\right)
and
H_\times =
0 & 0 & 0 & 0 \\
0 & 0 & 1 & 0 \\
0 & 1 & 0 & 0 \\
0 & 0 & 0 & 0
\end{array}\right)
where ##\mu = (t,x,y,z)##.
##\eta_{\mu\nu}## is the Lorentz metric (-1,1,1,1). [Corrected symmetry]
I believe ##h_{\mu\nu}## isn't the transverse part of the metric tensor field ##g## w.r.t. the timelike congruence given by integral curves of ##\frac {\partial} {\partial_t}## vector field in TT gauge coordinates. Indeed for any vectors ##X_p## and ##Y_p## both orthogonal to ##\left( \frac {\partial} {\partial_t} \right)_p## $$g_{\mu\nu} X_p^{\mu} Y_p^{\nu} \neq
h_{\mu\nu} X_p^{\mu} Y_p^{\nu}$$ given ##g_{\mu\nu} = \eta_{\mu\nu} + h_{\mu\nu}##
As I recall transverse refers to ##\partial^\mu h_{\mu\nu} =0## which is the case. EM waves are transverse in that E and H are orthogonal to the wave vector.
Ok, so that means that even though ##h_{\mu\nu} \left( \frac {\partial} {\partial_t} \right)^{\nu}= 0## , the metric ##g## restricted to spacelike hypersurfaces of constant coordinate time ##t## in TT gauge coordinates is not ##h_{\mu\nu}## (the latter is given in those coordinates as in post #14).
I don’t follow your question. [deleted synchronous gauge]
Paul Colby said:
H_\times =
0 & 0 & 0 & 0 \\
0 & 0 & 1 & 0 \\
0 & -1 & 0 & 0 \\
0 & 0 & 0 & 0
\end{array}\right)
Metrics are symmetrical.
TT gauge can only be obtained outside the sources. The 8 conditions are$$\partial^\mu h_{\mu\nu} =0 \quad ,\quad h_{0i}=0\quad,\quad h^\mu{}_\mu=0\quad.$$Although these exhaust all gauge freedom, they leave the possibility of a non-zero time independent ##~h_{00}~##. This is a Newtonian-like static potential, so for GWs (in linearized theory) we take ##~h_{00}=0~##. With this, the conditions above become$$h_{0\mu}=0\quad ,\quad h^i{}_i=0 \quad ,\quad \partial^i h_{ij} =0 \quad.$$The last one is the transversality condition, saying that the polarizations are perpendicular to the propagation direction: ##~n^\mu h_{\mu j}=~n^i h_{ij}=0~##, where the full metric ##g## is used, but only terms linear in ##h## are retained (this is like the Coulomb gauge condition in EM).
Maggiore's "Gravitational Waves Vol. 1" provides a nice and readable introduction to GW interferometers. After reading sections 1-3 of chapter 1, one can skip to chapter 9, where GW interferometry is discussed. In particular, it treats the basic effect in both the TT gauge, and in "detector's proper frame" (which by some justifications is replaced by Fermi Normal Coordinates").
Yes. They are the composite conditions for Lorenz + TT gauge. Namely, in Lorenz gauge $$\partial_{\mu}h^{\mu}{}_{\nu} - \frac {1} {2} \partial_{\mu} h^{\nu}{}_{\nu} = 0$$ the EFEs for linearized gravity in vacuum become ##\Box h_{\mu\nu} = 0##.
Take now as solutions the plane waves propagating in ##z## direction. Then adding on top the TT gauge conditions one gets
h _{\mu\nu}= \left(\begin{array}{cccc}
0 & 0 & 0 & 0 \\
0 & h_+ & h_x & 0 \\
0 & h_x & -h_+ & 0 \\
0 & 0 & 0 & 0
\end{array}\right)$$ In those coordinates the line element becomes $$ds^2 = - dt^2 + (1 + h_+)dx^2 + (1 - h_+)dy^2 + 2h_xdxdy + dz^2$$ As you can check ##h_{\mu\nu}## isn't the transverse of the metric tensor ##g_{\mu\nu}## w.r.t. the vector field ##\left( \frac {\partial} {\partial_t} \right)##.
0 & 0 & 0 & 0 \\
0 & 0 & 0 & 0
I don't understand your argument.
To first order in ##h~## $$\left( \frac {\partial} {\partial_t} \right) ^\mu h_{\mu\nu}=h_{\nu\mu} \left( \frac {\partial} {\partial_t} \right) ^\mu=0$$and$$\left( \frac {\partial} {\partial_z} \right) ^\mu h_{\mu\nu}=h_{\nu\mu} \left( \frac {\partial} {\partial_z} \right) ^\mu=0 \quad,$$so in this sense ##~h_{\mu\nu}~## is transverse to the ##t## and ##z## directions. That's what the TT conditions demand.
How should I calculate "the transverse of the metric tensor ##g_{\mu\nu}## w.r.t. the vector field ##\left( \frac {\partial} {\partial_t} \right)~##"?
Do you mean the projection of ##g## on the spatial hypersurface?
If that is what you mean, the answer is ##~\delta_{ij}+h_{ij}\neq h_{ij}~##. Why should it bother us in the present context?
Ah ok, transverse to both of them.
Do you mean the projection of ##g## on the spatial hypersurface? If that is what you mean, the answer is ##~\delta_{ij}+h_{ij}\neq h_{ij}~##.
Yes, that was my point (where ##i,j## run for 1,2,3). BTW, I believed that the projection of ##g## on the spacelike hypersurfaces was actually 4-dimensional though.
The hypersurfaces are 3-dimensional; therefore, any projection onto them must also be 3-dimensional.
I think this depends on the definitions used. For example in Lecture 18: Canonical Formulation of GR I, the metric tensor field ##h_{ab}## transversal to the orbits of the timelike vector fields ##u^a## is defined as ##h_{ab} = g_{ab} + u_au_b##. What is three-dimensional is the pullback of the metric ##g_{ab}##.
Yes, you can, if you like, define a 4-d tensor that is guaranteed to be transverse in the sense given.
But that 4-d tensor is not "the projection of ##g## onto the spacelike hypersurfaces". Defining a tensor that is guaranteed to be transverse is not the same as doing a projection of a 4-d tensor into a 3-d hypersurface. The latter operation gives you a 3-d tensor--a geometric object in the hypersurface.
AFAIK both approaches appear in the literature.
I had to look this up, possibly there is some confusion over wording. What I wrote was in the thread on Born rigidity, and what the spatial projector operator ##h_{ab}## was in that context.
The spatial projection operator ##h_{ab}## in general coordinates is a 4 dimensional linear operator (it has 4 coordinate inputs, in matrix terms it's like a 4x4 matrix or in tensor langauge rank 2 4 dimensonal tensor) which has the property that it maps vectors in the dimension that's being projected away (in this specific case, time) to a zero vectors.
If the coordinate axes are aligned property, one of the component of the projection will be zero and can then be dropped, but in generalized coordinates there's no gurantee that the coordinate axes will be so algined, and thus the output has 4 coordinates (as does the input).
Example: In the rotating disk in Born coordinates (t,r,theta,z) he projection operator h_{ab} projects the vectors in the spiraling timelike Langevian congruence to zero vectors, but because time time coordinate t isn't properly algined in Born coordinates, the t component of the ouput of the projection in general won't be zero.
I had to look it up as well. :wink:
Wald, Section 9.2, does use the term "projection operator" in the phrase: "projection operator onto the subspace of the tangent space perpendicular to ##\xi^a## (where ##\xi^a## is the tangent vector field to a congruence of timelike or null curves--in that section Wald only considers geodesics, but the same concept also works for a non-geodesic congruence).
Note carefully this phrasing: it is not equivalent to "projection onto a spacelike hypersurface". The tangent space is not in spacetime, nor is any subspace of it. Also, the congruence ##\xi^a## might not be hypersurface orthogonal, meaning that there is no such hypersurface in the spacetime to project onto. (Even if the congruence is hypersurface orthogonal, I think viewing the projection as onto such hypersurfaces is misleading, but that might be going too far afield for this discussion.)
So I withdraw my objection to the term "projection operator" by itself. But I still think "projection onto a spacelike hypersurface" is not correct.
Yes, agreed. Indeed the projection applies to the set of tensor fields defined on a tensor product bundle fiberwise (in this case twice covariant). This set doesn't carry a vector space structure so the projection is defined fiberwise (i.e. on each tensor product at point p).
I'm not sure what you mean by this. It doesn't seem to be the same as what Wald is saying.
I'm not sure what this means either. The subspace of the tangent space that Wald refers to is a vector space in its own right.
I'm not all that familiar with fiber bundles, but I keep running into them, so this might be a good example of how to think and talk about them. This isn't an answer to any question, but me trying to interpret your answer. I'm considering the Langevian congruence and how we can interpret it as a fiber bundle. We can consider the 4d space-time to be the total space, and the set of lines in the congruence as the base space, each point in the base space being identified with one line in the congruence . I actually assign coordinates to each line by choosing Born coordinates, taking t=0, and using (r, theta, and z) of the line at t=0 in Born coordinates as the coordinates of the base space, I'm not sure if this is necessary or not.
Now for the projection operator to be a fiber bundle, it has to satisfy some condition, a condition of local triviality. This is where my understanding is questionable. But I _think_ that the idea is that locally, every point in some small region of the total space looks like the tensor product of R^3 (the base space) multiplied by the time R (the fiber space) to give us a local product space of R^4, which satisfies the condition.
However, this projection operator I've discussed above is not ##h_{ab}##, or even ##h^a{}_b##. I suppose ##h^a{}_b## lives in the tangent space, it maps a vector in the tangent space at some point p to another vector that is orthogonal to the congruence at point p.
  • · Replies 39 ·
  • · Replies 31 ·
  • · Replies 0 ·
