Prove x2+y2+z2+w2=36 for Real Numbers x, y, z, w
To prove that x² + y² + z² + w² = 36 given the equation (x²/(n²-1)) + (y²/(n²-32)) + (z²/(n²-52)) + (w²/(n²-72)) = 1 for n = 2, 4, 6, and 8, start by substituting these values of n into the equation. This will yield four separate equations involving the variables x, y, z, and w. Solving these equations will provide the necessary relationships between the variables. The approach is straightforward and involves algebraic manipulation to derive the required result. The solution hinges on the consistency of the equations generated from the substitutions.
jeedoubts
if the real numbers x,y,z,w satisfy (x2/(n2-1))+(y2/(n2-32))+(z2/(n2-52))+(w2/(n2-72)) for n=2,4,6,8 then prove
x2+y2+z2+w2=36
unable to think of anything?:confused:
Unless I'm missing something, the problem you posted isn't consistent - what do your numbers x, y, z, w satisfy?
sorry the exact equation is as follows
[(x2/(n2-1))+(y2/(n2-32))+(z2/(n2-52))+(w2/(n2-72))]=1
please help:confused::confused:
Edit: Add "= 1" to make an equation below.
jeedoubts said:
if the real numbers x,y,z,w satisfy (x2/(n2-1))+(y2/(n2-32))+(z2/(n2-52))+(w2/(n2-72)) = 1 for n=2,4,6,8 then prove
x2+y2+z2+w2=36
You're unable to think of anything? The most obvious starting point is substituting n = 2, n = 4, n = 6, and n = 8, and seeing what you get.
That will give you four different equations in four unknowns -- in other words, exactly what is needed to solve the problem.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
