Prove Summation Property: \displaystyle\sum\limits_{i=1}^n aij
  • Thread starter Thread starter -Dragoon-
    Proof Summation
The discussion focuses on proving the summation property that states the equality of two double summations. Participants analyze the expression and provide a breakdown of the steps involved in the proof. One contributor suggests that a more rigorous approach is needed, recommending the use of induction and avoiding ellipses in notation for clarity. Additionally, tips on formatting mathematical expressions using tex tags are shared to enhance readability. Overall, the conversation emphasizes the importance of thoroughness in mathematical proofs and clear notation.
-Dragoon-
Show that the summation notation satisfies the following property:
\displaystyle\sum\limits_{i=1}^n(\displaystyle\sum\limits_{j=1}^m aij) = \displaystyle\sum\limits_{j=1}^m(\displaystyle\sum\limits_{i=1}^n aij)
N/A
\displaystyle\sum\limits_{i=1}^n(\displaystyle\sum\limits_{j=1}^m aij) = \displaystyle\sum\limits_{i=1}^n ai_{1} + \displaystyle\sum\limits_{i=1}^n ai_{2} + ... +\displaystyle\sum\limits_{i=1}^n ai_{n} = \displaystyle\sum\limits_{j=1}^m(\displaystyle\sum\limits_{i=1}^n aij)
Have I proven this sufficiently or have I skipped a step? If I skipped a step, which one was it? Thanks in advance.
Show that the summation notation satisfies the following property: \sum_{i=1}^n\bigg(\sum_{j=1}^m a_{ij}\bigg) = \sum_{j=1}^m\bigg(\sum_{i=1}^n a_{ij}\bigg)
N/A
\sum_{i=1}^n\bigg(\sum_{j=1}^m a_{ij}\bigg) = \sum_{i=1}^n a_{i1} + \sum\limits_{i=1}^n a_{i2} + \cdots +\sum_{i=1}^n a_{im} = \sum_{j=1}^m\bigg(\sum_{i=1}^n a_{ij}\bigg)
I would at least have written out the step \sum_{i=1}^n(a_{i1}+\cdots+a_{im})=\sum_{i=1}^n a_{i1} + \sum\limits_{i=1}^n a_{i2} + \cdots +\sum_{i=1}^n a_{im}. If you want to do these things rigorously, you need to avoid the ... notation and use induction.
If you use tex tags instead of itex, you don't need to type "displaystyle" all the time. (Use tex tags only when you want the math to appear on a separate line). Hit the quote button to see how I prefer to type the math above.
Thank you for the help and the tex tips, Fredrik.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
