Building an infrared heater element
The discussion focuses on building an infrared heating element for curing epoxy at 350°F, utilizing nickel-chromium resistance wire. The user seeks to calculate the necessary watt density of 7 watts/in² for a 15"x15" heating panel, totaling 1575 watts. Questions arise about using bare wire as a heating element and the impact of protective coverings like glass or fiberglass on heating efficiency. The conversation also touches on safety and regulatory considerations for marketing the device. Additionally, there is curiosity about the heat transfer properties when using a ceramic or fiberglass blanket to enhance infrared radiation.
privitmj
So, as the title describes, I am trying to build an infrared heating element for my own heating panel. I want to use this heater to cure an epoxy at 350F that is about 5" away. I'm an EE so the wiring and such will be simple but the heating calculations are beyond my area of expertise. Here is my train of thought so far:
1. I want to use nickel-chromium resistance wire to make an element.
- How do I calculate the amount of heat this wire will give off?
- I am told that I need a watt density of 7 watts/in2 for my application. I want
the heater panel to have a heating surface of 15"x15" so depending on the
diameter and resistance of the wire i can pick the correct size amount of wire.
- Can I use this wire bare? I know there are different types of heaters but I don't know
if I've ever seen one with just bare wire as a heating element.
- Most companies use either a glass or fiber glass face to cover the element (basically
for protection purposes I'm told). Does this effect my heating capabilities?
2. What are my other options as far as creating a heating element go?
Lets see
15x15 = 225 sq inches
7 watts/ sq inch
gives 1575 watts
if that is the understanding of stipulation you have mentioned
A regular toaster for your kitchen has bare wire.
You can use glass ( make sure it is the correct type of glass for thermal application and not regular window pane glass ) or a wire mesh so you can't poke your fingers inside.
With glass you also canot poke a stick or metal rod inside, which may be regulatory if you plan on marketing and selling your device.
Yes, the watt density is easy to calculate. I was trying to figure out what temp I had to get the coil to in order to get my epoxy (about 5") away up to temperature. I did find the answer to that question though.
Does anyone know what type of heat transfer I'll get if I wrap the coil in a cermaic or fiberglass woven blanket? I assume the blanket will need to be heated via conduction and then the blanket becomes the infrared radiator?
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
