Is a Collision Between Three Molecules Necessary for the Formation of 2SO3?
The discussion centers on the reaction 2SO2(g) + O2(g) -> 2SO3 and the misconception that it requires a direct collision between one O2 molecule and two SO2 molecules. It is clarified that while the formation of an intermediate like S2O6 might seem plausible, it does not accurately represent the reaction mechanism. Instead, the reaction is more likely to occur in a series of steps rather than a single collision involving all three molecules simultaneously. This highlights the importance of understanding reaction mechanisms, as the overall equation does not necessarily depict the actual process by which the products are formed.
muhsentdrawji
For the reaction, 2SO2(g) +O2 (g) ->2SO3. Why is it wrong to say that the reaction must involve a collision between one O2 and two SO2 molecules? Don't they form S2O6, which is equivalent to the product, 2SO3? What should I say then, about the reactants in forming 2SO3? Thank you so much!
Chemistry news on Phys.org
It is quite unlikely for three molecules to bump at each other with correct energies at the same time. It is much more likely that the reaction occurs in steps, and the total reaction equation doesn't reflect the mechanism.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
