Expanding parenthesis when a negative is involved
  • Thread starter Thread starter educatingrob
    Expanding Negative
The discussion revolves around expanding the expression (x-2y)^2 - (2x-y)^2, with a focus on handling the negative sign correctly during the expansion process. Participants explain that introducing a multiplication by -1 can simplify the expansion, allowing for easier calculations. They emphasize the importance of using parentheses to manage negative signs and clarify that multiplying two negatives results in a positive. The conversation also touches on the binomial theorem as a method for solving such expressions. Overall, the thread aims to demystify the rules of expansion involving negatives for those revisiting basic algebra concepts.
educatingrob
Im completing Engineering Maths cover to cover in an attempt to get more familiar with maths as I finished my education many years ago without really understanding many basic maths concepts. This problem is at the back of the introduction to algebra.
(x-2y)^2 - (2x - y)^2
Now I can expand fairly easily:
x(x-2y) - 2y(x-2y) - (2x)(2x-y) - (-y)(2x-y)
x^2 - 2yx - 2yx + 4y^2 - 4x^2 ... Hmm
I know the rest as its in the book but I don't know the correct method for determining:
- (-y)(2x-y)
because of the negative at the front. without it, its easy:
-y * 2x = -2xy
-y * -y = y^2
thus:
-2xy + y^2
but then you have ... - -2xy + y^2
minus minus?
What I don't understand is how the negative before the brackets affects the result. When expanding is it:
- (-y)(2x-y)
-y * 2x = -2xy * -1 = 2xy
-y * -y = y^2 * -1 = -y^2
or maybe the - term belongs to all the last bit?
- (-2xy + y^2)
so its
-1 * (-2xy + y^2)
= +2xy - y^2
If someone could explain the rule dictated to expand when there's a negative, I would be grateful as I can't find an example or comment about how to think of this.
Of course there's the other FILO way (a+b)(c+d) = ac+bc+bd+ad
but that's just confusing me more WRT expanding the two elements of (x-2y)^2 - (2x - y)^2 because of the negative.
My maths is riddled with these inconsistencies where I just used to guess without understanding what's missing or what rule to follow.
(apologies for the stupid question, thanks for any help)
Mathematics news on Phys.org
This is very elementary stuff... a high school teacher could probably explain it better. You can always replace a - by a multiplication with (-1). So - (-y)(2x-y) = (-1)\cdot (-y) \cdot (2x-y) Now there are many ways to calculate the results. The easiest is this one: (-1)\cdot ((-1) \cdot y) \cdot (2x - y) = (-1)\cdot (-1) \cdot y \cdot (2x - y)= y \cdot (2x - y) = 2xy - y^2 because (-1)\cdot(-1)=1 Btw a - b = a + (-1)\cdot b and your equation would usually be solved using the binomial theorem...
Looks to me that you got the right answer by both methods above.
You can think of -n as +(-1)*n. So - (-y)(2x-y) = +(-1) (-y)(2x-y). Multiplying the first two terms together gives +y(2x-y). Or multiplying the last two terms first gives +(-1)*(-2xy+y^2) = 2xy-y^2.
The simplest, and safest way is to introduce a new parenthesis between the expression to be expanded, and then solve that paranthesis later. You can ALWAYS place as many parentheses you want about a single term.
So:
-(2x-y)^2=-((2x-y)^2). Now, internally, there is no dangerous minus sign, so you can proceed
-((2x-y)^2)=-(2x(2x-y)-y(2x-y))=
-(4x^2-2xy-2xy+y^2)=-(4x^2-4xy+y^2)=-4x^2+4xy-y^2
Annoyingly Id just typed out a long response and the session timed out when I went to post it
Anyway,
I managed to factorize
(x-2y)^2-(2x-y)^2
to
3(y^2-x^2)
via, as you posted introducing (-1), more parenthesis.
i.e.
(x)(x-2y)(-2y)(x-2y)(-1)(2x)(2x-y)(-1)(-y)(2x-y)
The last time I was around high school teachers was 20 years ago and for whatever reason, I didnt get it then ;) Seems elementary now though.
Thanks all :)
Just looking at the binomial theorem.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
