Why do we use plus/minus signs in front of radicals?
  • Thread starter Thread starter tahayassen
    Radicals
The discussion clarifies the use of plus/minus signs in mathematical expressions, particularly in relation to radicals. It emphasizes that the notation "±" signifies both positive and negative solutions, which is essential when solving equations like x² = 4, where both x = +2 and x = -2 are valid. The conversation highlights that using a single plus or minus sign would be insufficient to convey the dual nature of the solutions. Additionally, it points out that while plus/minus signs can indicate two separate cases, they are not always applicable in all mathematical contexts, especially with even roots. Ultimately, the distinction between "±" and "+" or "−" is crucial for accurate mathematical communication.
tahayassen
±\sqrt { { x }^{ 2 } } \\ =±|x|\\ =±±x
Wouldn't a plus sign or a minus sign be sufficient?
Mathematics news on Phys.org
hi tahayassen! :smile:
you mean, wouldn't one plus-or-minus sign be sufficient?
yes, you can just write "√(x2) = ±x" :wink:
The last step is either false or misleading nobody would write that. It means in one case ++x and in the other case --x which is both the same as x and not what you wrote on the line above. Plus-minus signs are used if one wants to say that there are two equations that apply in different cases, and that are only distinguished by different plus or minus signs. It's a way to express your thoughts and not a rigorous 100% correct way to write mathematics. If one wants to be clear one has to write cases like
"c=a+b if condiction X and c=a-b if condition Y."
plus/minus signs
You should also note that plus/minus signs written as in your thread title means something different.
+/- means plus or minus, but not both, ie only one will satisfy the statement.
So an object that slides up and down a vertical pole can be moving up (y +ve) or down (y -ve) but not both.
± means both plus and minus (satisfy the statement)
The equation x2 = 4 is satisfied by both x=+2 and x=-2
Plus/minus signs are not aways used in front of radicals. The n-th root is a function which means it can produce only one output. In the case where n=even number the square root is positive number which rised to the power of n gives the original number. However negative numbers risen to even power give the same answer as the same positive numbers. When you solve equations you usualy need both cases.
And yes +/- sign mean both cases separately for example :
(x \pm y)^2=x^2 \pm 2xy+ y^2 This is basicaly the two cases in one equation :
(x + y)^2=x^2 + 2xy+ y^2
(x - y)^2=x^2 - 2xy+ y^2
This last step is incorrect. \pm\sqrt{x^2} is the same as \pm |x| but |x| is NOT the same as "\pm x" so \pm |x| is NOT the same as "\pm\pm x".
How would you chose which?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
