What is the relationship between the Wronskian and linear independence?
  • Thread starter Thread starter CPL.Luke
    Concept
CPL.Luke
hmm I don't think I have the concept of the wronksian down all the way yet.
mainly I'm having trouble seeing how the the wronksian not equaling zero implies that all the solutions are linearly independant of each other.
Wronskian
Remember when back in Algebra you had to decide wether two lines were parallel, or the same line? When the distance between the two lines you had to work with was zero, you decided that this could only be when the two lines are one and the same, point for point. Think of that analogy here.
First of all, getting zero for a Wronskian does not imply linear dependence - that's only when the Wronskian is identically zero - which means zero for all X. [Pretty strict condition]. When you use the Wronskian to check for linear independence, what you are actually doing is checking if the two solutions are multiples of each other. If you calculate the Wronksian and get identically zero, that is, zero for every point on the interval, that means that that the functions are linearly dependant. If the Wronskian yields anything else, the solutions are linearly independant and they are not multiples of each other. I hope this helps!
If you have n functions, fi(x), and n numbers, ai, such that a1f1(x)+ ...+ anfn(x)= 0 for all x, then you can make that into n equations for the ais by taking n derivatives (to get n equations) and taking x= 0 (or any other fixed number). The Wronskian, in that case, evaluated at x= 0 or whatever number, is simply the coefficient matrix. As long as that matrix does not have 0 determinant, you could find the unique solution multiplying by its inverse matrix. Obviously, ai= 0 for all i is a solution. If the determinant of the Wronskian is not 0, it is the only solution and so the functions are independent. If the determinant is 0, then there is no unique solution. (In general, if the determinant of the coefficient matrix for n equations is 0, either there is no solution or there are an infinite number of solutions. In this case, ai= 0 is an obvious solution so there must be an infinite number of solutions.)
but then why do we differentiate the function to fill up the matrix?
Then you can use it to show a homogeneous linear DE of order N cannot have more than N linear independent solutions by just taking a linear combination of rows. If y is a solution to the DE, then the D.E. for y is just a coefficient of the vector from a linear combination of the rows of the Wronskian
All I can do is repeat what I said before:
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
