Servo motor duty cycle vs. supply voltage
The discussion revolves around the effective supply voltage required for a servo motor controlled by a PID controller, which currently operates at a 50% duty cycle. The user calculates an effective voltage of 2V, factoring in a 1V drop across the driver, leading to a conclusion that the servo should handle a supply voltage between 9-15V. The response clarifies that the voltage limit depends on whether it is instantaneous or average; if average, the user's calculations are deemed correct. The importance of understanding the nature of the voltage limit is emphasized for proper servo operation. This highlights the need for precise calculations when determining supply voltage for optimal performance.
280Z28
I have a servo motor that I'm controlling with a simple PID controller for a constant frequency square wave with varying duty cycle. My supply voltage is 5.17V with ~1V drop across my low side driver. The controller sits right around 50% duty cycle to keep the servo open to position A. A reference source states that it should take a 14-26% duty cycle to keep it open to position A. What should the supply voltage be, counting again a 1V drop across the driver?
By my calculation, I've applied an effective (time averaged) 2V source.
2/.26 + 1 = 8.7V
2/.14 + 1 = 15.3V
Is this the correct calculation/conclusion that the servo is built to handle a 9-15V supply?
That depends on the nature of the 9-15V limit. If it is instantaneous (unlikely) then duty cycle doesn't matter. If it is average (more likely) your calculation is correct.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
