Solve Sat Math: Find # Passengers on Bus Now
  • Thread starter Thread starter hkhero
    Sat Sat math
A bus picks up x passengers at the first stop and y passengers at the second stop, then 2/3 of the passengers exit at the third stop, followed by 2 more passengers getting on at the fourth stop. The discussion revolves around finding the current number of passengers on the bus using the equation derived from these steps. One participant suggests using direct calculation rather than plugging in numbers, emphasizing that the bus should start with zero passengers. Another participant initially used a wrong assumption of 20 passengers before the route began, which led to confusion in their calculations. The consensus is to solve the problem directly in terms of x and y for accuracy.
hkhero
At the first stop on its route, a bus picks up x passengers. At the second stop, y passengers get on the bus. At the third stop, 2/3 of the passengers exit the bus. At the fourth stop, 2 passengers get on the bus. How many passengers is the bus carrying right now?
a) (3x+3y+4)/3
b) (2x-2y-4)/3
c) (6-2x-2y)/3
d) (x+y+6)/3
e) (3x+2y+6)/3
I'm jux wondering hwo can u do this by using PLUG INS... thanks a lot... btw the answer is D.
Mathematics news on Phys.org
In my humble opinion, you should just figure it out directly, without resorting to some trick.
But if you're dead set on plugging things into solve the problem... then do it by plugging things in. :-p If you're having problems, then show us what you've done, and where you're stuck!
thatZ wt i did:
for ppl whoz orignally, i put 20 for that, then for x i put 3, and for y i put 4.
so first stop itz 20+3,
second stop itz 23+4,
third 27 * (1/3) = the ppl whoz left in the bus
fourth 9+2
so the total number is 11, but i couldn't find the answer... help! i think i have a problem about setting the original number of the bus.
Ah, that's your problem. The bus shouldn't have any passengers on board before it starts servicing its route!
so it should be 0 for the orignally passenger?
Before the bus picks up x passengers, it should have zero on board. Otherwise, it kind of defeats the point of having a first stop.
I highly recommend you solve it by seeing how many passengers there must be in terms of x and y directly, otherwise you're going to be using a weak method that will only fail you later (or if it's not multiple choice)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
