What are those bubbles in my beer?
  • Thread starter Thread starter Brock
    Beer Bubbles
Alcohol does evaporate, and while some ethanol may be lost when beer is left standing, the rate is significantly slower than that of carbon dioxide. The presence of carbon dioxide in beer helps maintain the ethanol in solution, contributing to the beverage's overall flavor and freshness. Although a small amount of alcohol may evaporate, it is unlikely to significantly affect the alcohol percentage in the beer before consumption. The discussion highlights the balance between carbonation and alcohol retention in beer, emphasizing that while evaporation occurs, it is minimal in practical terms.
Brock
I heard alcohol evaporates, also the carbon dioxcide pop does the samething, am I loseing alcohol percentage when I let my beer stand?
Chemistry news on Phys.org
Judging by your typing skills, I'd venture you're still getting plenty.
- Warren
No. It would take a very, very, very long time for any chemical reaction to take place. People often forget that alcohol isn't like other drugs like THC or Ex in which the active ingredient has a very small mass...Alcohol takes up a lot of space. In some spirits (100 proof) the alcohol itself takes up 50% of the volume. Unless your beer is shrinking, I'd say you're safe.
Most of it is carbon dioxide, ethanol has a considerable vapor pressure so yes, some ethanol is evaporating out of the solution, however not as fast as the carbon dioxide although I wonder just what role carbon dioxide has, if any, in keeping the ethanol in the solution.
Im pretty sure its carbonated just like soda pop to help slow down the reactions that might occur that would make it taste bad before you had a chance to drink it. Also I think that people prefer the taste of a carbonated beverage over a "Flat" one because it has a taste people relate to "fresh".
I would have to guess that 99.9 percent or so is o=c=o and the other .01% CH3-CH2-OH of what evaporates by the time you drink it. Actually the EtOH is probably a bit higher because i know beer smells really strong sometimes.
I could be wrong though on the first part... oh look at the time its beer thirty. Time to go drink!
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
