Calculating Water Rocket Force: Velocity, Time & Mass
The force of a water rocket is determined by the reaction mass, which is the water ejected. To calculate the change in mass of the water, one needs to know the velocity and time of the water being expelled. Without these values, it is impossible to accurately determine the force exerted by the rocket. The discussion highlights that increasing air pressure in the rocket can enhance the speed of the water, thereby affecting the rocket's velocity. Ultimately, an independent method to measure the water's exit speed is necessary for precise calculations.
Db75
Hi,
I understand that the force with which a water rocket is accelerated is equal to the force of the reaction mass (or water) sent in the other direction.
If the change in mass of the water as it is being ejected can be calculated from this equation:
change of M = area of exit x water density x (velocity of water x time)
How am I supposed to find out the change of mass if I have no idea what the velocity and time is?
Do I have to compare that with the velocity of the rocket (which I know)?
Thanks
OK this is what I have now:
F = delta(mv) / delta t = (density x exit area x v^2)
But, I have no idea what v is.
I know that the acceleration of the rocket is equal to (v^2 / 2) / displacement, and so F = ma which equals the force of the reaction mass.
Hmm I may have answered my question..
But just so I know-
Without knowing the velocity of the water, there is no way I can work out the force..that would depend on the air pressure and all that...correct?
I'm sure it has occurred to you that if you take exactly the same amount of water but increase the pressure in the rocket (by pumping air in) the rocket will move faster. Unless you have some indendent way of calculating the speed with which the water leaves the rocket you will not be able to calculate the speed of the rocket.
Yes.
Thanks for your input.
