Finding the locus of points for complex analysis
calculuskatie
I think this should probably be easy, but I am stuck. My book is of no help.
Find and describe the locus of points z satisfying the given equations:
1. |z-i|=Re z
2. |z-1|^2 =|z+1|^2 +6
I am thinking for the 1st one that I have to square both sides, but then what? What happens to Re z?
For the second one, I am totally lost. My first instinct would be to take the square root of both sides...and then...?
Thanks to all.
Welcome to PF!
1. |z-i|=Re z
Hi calculuskatie! Welcome to PF! :smile:
Hint: |z - a| is just the distance from z to a.
So just use geometry (including the cosine formula for triangles).
How would you describe those two equations in geometry? :smile:
Have you tried replacing z by x+ iy so that each equation becomes an equation in x, y?
That should make the curves easier to recognize.
For example, if z= x+ iy, then z- i= x+iy- i= x+ (y-1)i and so |z-i|= |x+ (y-1)i|= \sqrt{(x+ (y-1)i)(x- (y-1)i)} (because |z|= \sqrt{z \overline{z}})
= \sqrt{x^2- (y-1)^2} and, of course, Re(z)= x. What kind of graph does \sqrt{x^2- (y-1)^2}= x give? (Try squaring both sides.)
Another, more geometric way to do this is to note that |z- i| is the distance from the point z, in the complex plane, to the point i. Re(z), on the other hand, is the distance from z to the y-axis. What kind of figure has distance from a point on the graph to a point equal to the distance from that point to a line?
