The instantaneous velocity of a freely falling object
The instantaneous velocity of a freely falling object after 10 seconds is calculated to be 98 m/s using the formula v = gt, where g is approximately 9.8 m/s². The average velocity during this interval is determined to be 49 m/s, calculated by averaging the initial and final velocities. The distance fallen in this time is 490 meters, derived from the equation d = ½ gt². Some variations in calculations arise from using different values for g, such as 10 m/s² instead of 9.8 m/s², but they yield similar results. Overall, the methods discussed are interrelated and yield consistent conclusions regarding the motion of the object.
sammyj
What is the instantaneous velocity of a freely falling object 10 s after it is released from a position of rest? What is its average velocity during this 10 s interval? How far will it fall during this time?
I had asked a few friends for help and I keep getting mixed answers.
v = gt
98m/s = 9.8m/s * 10
Average V = initial v + final v
Average V = 0m/s + 98m/s
Average V=49m/s
Distance Traveled d = ½ gt squared
½ * 9.8m/s * 10 squared = 490m
or
Vf=Vo+at = 0msec+10msec2(10sec)= 100msec
AverageVelocity=Vf+Vo2=100ms+0ms2=50msec
X=Vot +12at2=0ms(10sec)+12(10msec2)(10sec)2=500 meters
Who's on the right path?
Welcome to PF.
You can approach average velocity either way.
V = a*t => Vavg = 1/2*a*t
or X = 1/2*a*t2
Vavg = Xtot/Ttot = 1/2*a*t2/t = 1/2*a*t
V2 = 2*a*x = 2*a*(1/2*a*t2) = a2t2
V = a*t
They are all interrelated.
The answers came up slightly different would it matter?
There is no difference that I see. Acceleration is due to gravity in both cases.
The bottom equation uses g = 10 instead of 9.8.
