Power Supplies, resistors, and ohm's law
A 12V 10A power supply can be safely used with a 12V 3A motor, as the motor will only draw the current it needs, which is 3A. The power supply's higher amperage rating indicates its capacity, not the amount it forces through the motor. However, if the motor experiences a high inrush current at startup, it could exceed the power supply's limits, potentially causing it to shut down. To mitigate this, a series resistor and switch can be used to limit initial current during startup. Overall, the motor's internal resistance dictates its current draw, making it compatible with higher-rated power supplies.
StephenDoty
Hey
I have a 10amp 12v power supply and a 12v 3amp motor. Is there any way to add enough resistors to use the 10amp power supply with the 3 amp motor? If not is there any thing that I can put in line with the motor and power supply so the 10amps won't burn up my motor?
Thanks
Stephen Doty
You can use it without any resistor. 12V 10 amp only mean the supply is capable to supply 10A, you can use only 3A out of 10A. It is the voltage that is important. You have a 12V motor, so you can hook directly onto the 12V 10A supply and it will only draw 3A and both the supply and the motor will be happy!
so even if I get a 40amp 0-30v power supply and set it to 12v, the motor will pull only 3 amp from the power supply even if it is on 40amps?
You stated that you have a 12 volt 3 amp motor, but you didn’t mention at what RPM the motor draws 3 amps. The current that a motor's armature draws varies with armature RPM.
The commonplace PMDC motors for instance, draws maximum current at start-up (armature motionless). As the armature begins to increase in RPM, a back emf voltage is generated that is proportional to the armature's angular velocity. This generated back emf voltage opposes the applied voltage thereby reducing the amount of current that will be drawn through the armature windings from the applied voltage source.
The electric fuel pump on my vehicle draws a steady 3 amps at its high RPM operating RPM, but when 12 volts is initially applied (armature motionless), the instantaneous current draw briefly exceeds 12 amps. The fuse is only rated at 10 amps, but it's a slo-blo fuse. The fuel pump armature accelerates so quickly that the current very rapidly decreases to the steady 3 amps, which prevents the fuse from producing enough heat to blow the fuse. Even so, my vehicle’s battery and its electrical wiring are capable of handling this load.
If your particular motor happens to also draw an instantaneous current that just briefly draws 10 amps or more, it may cause your power supply to crowbar and shut down. In this case, you may have to install a series resistor and a 3-position switch. The positions would be for: Off, Start, & Run. Upon start-up, the switch position places a current limiting resistor in series with the motor’s armature windings so as to limit the initial high start-up current. Once the motor has come up in speed (its current demand reduced), simply flip the switch to Run and the series resistor is eliminated and the motor runs directly from 12 volts with its normal torque and velocity for the given physical load.
Yes! Even the power supply has 40A capability, the motor has internal resistance that can only draw 3A at 12V. The amprage of the power supply tell you how much it can put out. Current drawn is governed by the load.
You put a 1K resistor across a 10V power supply that can provide 10A, the resistor will only draw 10mA as long as the power supply put out 10V. This is just as simple as I=V/R!
I am not counting on any of the start up current surge like the other responder said and anticipate what if the the motor get stalled because you have not mentioned any of that. If you have other more complicate situation, please specify it.
You ask a simple question, I give you a simple answer! If you get into it, you can always adjust the current limit of the supply, put a fuse etc. But that is out of the context and it can get complicate.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
