Writing Equations for Position, Velocity, and Accelerations as functions of time
The discussion focuses on deriving equations for position, velocity, and acceleration of a projectile launched from a cliff. The projectile's initial speed is 50.0 m/s at a 40.0-degree angle, with gravity set at 10.0 m/s². It emphasizes that projectile motion is influenced solely by gravity, leading to constant acceleration. Participants suggest using kinematic equations or calculus to derive the necessary formulas. Resources for understanding these concepts and formulas are also requested.
Jordash
A projectile is launched with a speed of 50.0 m/s and an angle of 40.0o above the horizontal, from the top of a 75.0 m high cliff onto a flat valley floor at the base of the cliff. Assume that g = 10.0 m/s2 and ignore aerodynamic effects.
Write equations for position, velocity, and acceleration as function of time for the projectile.
I've been looking through the time functions but I can't seem to figure out how to write these equations. Any help would be greatly appreciated.
It's a projectile motion problem. What is a projectile? An object that, once set into motion (launched) travels solely under the influence of gravity. Gravity is a constant force (it isn't really, but it is for our purposes, unless you're traveling really large vertical distances). So you already know that the acceleration is constant (doesn't change with time). From that you can either work backwards using calculus to find the velocity and position. OR, if you haven't studied calculus, then your teacher will have taught you kinematics formulas that *describe* the motion of an object under constant acceleration (formulas that are derived from calculus), and you can just *use* them.
I didn't really understand our teacher when he taught those formulas, is there a place I can look which teaches the formulas i'll need to use?
accident put wrong post in this forum
