How Can You Master Acid Etching on Steel Knife Blades?
The discussion centers on techniques for acid etching tempered steel, specifically for creating designs on stainless knife blades. A newcomer seeks advice on suitable mask coatings that can accommodate fine lines while maintaining sharp edges, as well as recommendations for safe acids to use. Suggestions include utilizing photoresist etching methods similar to those used in PCB manufacturing, which can yield sharp edges. Ferric Chloride is recommended as a common etchant, with a dilution ratio of four parts water to one part Ferric Chloride, and heating the solution to around 150 degrees can enhance the etching speed. For masking, fingernail polish is suggested, as it can be easily scribed and removed with acetone post-etching. Additionally, a method involving a salt solution and electrical current is mentioned, though it requires caution due to chlorine gas production.
334dave
hi , i am newbie here and reading through i find it ... stimulating..
now as to what brought me here..
i have wanted to look into art form of acid etching different knids of tempered steel
used in stainless knife blades..
does anyone there know what mask coating will take a fine line scribed in it yet still give me a good sharp edge and what acids are best or safest to use..
i have Googled the subject and find nothing related to art acid etching or instructions or how to
only the photo / electro marking systems which do not produce fine sharp edges ..
also if some one knows of a site devoted to this a url would be nice..
thanks !
Chemistry news on Phys.org
btt anyone know? or should i check a diff forum?
btt still looking..any one?
I'd suggest using the photoresist etching method used for making PCBs.
It does give fairly sharp edges (look at a circuit board), if done correctly.
Ferric Chloride, sold at Radio Shack as an etchant for electronic boards is commonly used as an etchant for knife blades. I dilute mine about 4 parts water to 1 part Ferric Chloride. Also it etches faster if the solution is heated to about 150 degrees or so.
For a mask coat you can use fingernail polish. When dry scribe your line in it. After etching remove the fingernail polish with acetone. I use Red nail polish because it is easy to see and easy to make sure you have all of it removed.
I also have a written procedure for etching using a salt solution and an electrical current, works well for small stuff but remember that introducing an electrical current into salt water produces chlorine gas. You have to make your own stencil though but that can be done with scotch tape.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
