Calculating Stress in Beam Under Point Load: Best Methods
To calculate stress in a beam under a point load using deflection, three key equations are necessary: one for deflection based on load, length, modulus of elasticity, and moment of inertia; one for bending stress related to moment; and one for shear stress related to shear force. Bending stress varies with height, being maximum at the top and bottom fibers, while shear stress is parabolic and zero at the mid-plane. The bending stress can be calculated using the formula sigma_B = M_max * Z/I, where I is the moment of inertia. Shear stress is linear and also needs to be considered, particularly at the extreme fibers. Understanding these principles is essential for accurate stress calculations in beam mechanics.
ladil123
Hello!
If I know the deflection (w) of a beam subjected to a point load in the middle, can I calculate the stress in that beam by calculating the shear force or moment ?
or use a 2d plane strain state ?
What is the best way to do it ?
Thanks
Yes. You need three equations:
deflection of beam as a function of (P,L,E,I)
bending stress of beam as a function of moment.
shear stress of beam as a function of shear.
Then you need to add the two stresses together, but they almost always don't add linearly. Bending stress is varies with the height, y, within the section; ie: high at both top and bottom fibers, and zero at the mid section. Shear stress is parabolic, with its maximum at the mid section. A bit of reading will reveal what shear stress engineers usually use at the extreme fibers (it is not zero).
This is all in most books on "Mechanics of Materials".
Shear stress is linear and is zero at the mid plane. Bending stress is parabolic.
You had them backwards
Ok.
So the bending stress sigma_B = M_max *Z/I , right? I=moment of inertia.
What about the stress due to shear then? With the equation for deflection I could integrate and get the shear force, but how do I get the shear stress ?
I guess I wasn't clear. I was referring to the transverse stress level within a SECTION of the beam, and not referring along its length.
What you said is true but for longitudinal stress along the length.
I think I didn't get the question.
Yeah if you know the deflection, you can apply hooks law and figure out the stress.
But for that you also need to know 'sigma'; the constant.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
