Can the Brain Take In New Information when Asleep?
  • Thread starter Thread starter mikesmith1287
    Brain Information
The discussion centers on the brain's activity during sleep, particularly regarding the processing of information. It is acknowledged that while the brain sorts and organizes information acquired during waking hours, the capacity to learn new information during sleep is limited. Participants note that external stimuli, like sounds or vibrations, can intrude on dreams but do not facilitate effective learning. Listening to audiobooks while sleeping may lead to dreams related to the content, yet this does not equate to actual retention or learning. Psychological experiments have indicated that the brain is not designed for learning during sleep, reinforcing the idea that any learning that occurs is likely inefficient. Overall, the consensus is that while some processing happens during sleep, the brain is primarily focused on organizing previously acquired knowledge rather than absorbing new information.
mikesmith1287
Hello everyone. I have become very interested in how the brain works recently. I know that in sleep, your brain is basically going through all of the information that it has obtained, and sorts through it (decides what is/is not important, and strengthens/weakens those connections).
But,
Can you take in new information when asleep, or is your brain just sorting through what it already knows?
Chemistry news on Phys.org
It most certainly can. Have you never had sights, sounds, smells or vibrations from reality intrude on your dreams?
Yes, but it's almost like it goes right through you.
If you fall asleep listening to a book on tape you will not remember any of it when you wake up. You might however have a weird dream related to something in the book.
If you fall asleep listening to a book on tape your ears will hurt when you wake up.
I remember reading about psychological experiments done about learning while sleeping. They have not produced new teaching methods, so obviously our brains are not wired to learn when asleep, although I recall some information about data being sorted and stored during night. But that was data acquired during a day.
Cool. Thanks for the reply guys!
David, but if you might have a weird dream about the book you were listening to, then doesn't that mean that you are sort of learning something new?
I see that we are not wired for learning when we are sleeping, but maybe we can still learn, but just very inefficiently?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
