HDMI / Component Video Switches
HDMI and component video switches are essential for managing multiple TVs in a setup where only one TV has HDMI input. Users can utilize component video switches to output signals from devices like the Wii to multiple TVs without needing to switch cables manually. Concerns about signal quality when splitting component audio/video signals are valid, but component video switches can maintain signal strength and quality. It's noted that while these switches typically allow multiple devices to connect to a single input, they can also be used to split signals to multiple outputs. Monoprice is recommended as a reliable source for purchasing these switches and splitters. Testing a simple splitter is suggested as a potential solution before investing in more complex hardware.
minger
HDMI / Component Video "Switches"
Hi guys, I just entered the HDTV realm and I'm having a little difficulty setting up my system. I don't have any place to put old extra TVs, so I have three (no, the girlfriend doesn't like it) TV's basically side by side.
Are there splitter switch things so that I could output my PS3/Wii to 2 of the TV and use a box or something to chose which TV it goes to?
Basically I'd like to be able to use everything on the new TV, but if it's in use, I'd like to be able to hit a switch and output it to one of the auxiliary TVs without switching wires which is what I'm doing now and I think it bush league.
Thanks a bunch,
edit: Actually only the new TV has HDMI input, so I would only need to "split" the Wii's component audio/video. I would think that simply splitting them would lose quality/signal. Am I correct in this thinking?
Computer science news on Phys.org
Yes, there are such things as component-video switches. I used one myself for a while before I converted all my HD connections to HDMI. Here's an example:
http://www.monoprice.com/products/subdepartment.asp?c_id=101&cp_id=10112
I didn't actually use this one, but I bought my current HDMI switch from this company, and they're well-regarded as a source for good, inexpensive audio/video cables, connectors, switches, etc.
I think that's the opposite of what I want. I don't need "extra" inputs or expand the number of inputs my televisions I have; I have plenty.
Rather I'd like to be able to output the signal from my Wii to two televisions without loss of quality. I suppose the first question before hardware would be if simply splitting the signal of the component audio/video will result in losses of quality/strength?
As far as I know, component-video switches can pass the signal in both directions, so they should work for what you want. It's simply that most people use them as I did, to allow more than one device to use a single input on a TV.
You won't be able to watch the same thing on more than one TV, of course.
Monoprice also sells component-video splitters, but I don't know how well one would work in your situation.
http://www.monoprice.com/products/subdepartment.asp?c_id=104&cp_id=10422
Maybe the solution is to pick up a cheap splitter and see how well it works. If it doesn't work well, try picking up a switch and use it in reverse.
Thanks,
I have used a plain old A/V switch for Component Video. They both use RCA connectors and the L/R audio connectors could be used for video. In this case the audio was going to stereo and not the television. The stereo had enough inputs so each source has it's own connectors.
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
