MichielM
- 22
- 0
Consider a source/sink in the origin of a coordinate system with a strength equal to 2m and two sources/sinks, each with a strength of −m, i.e. with a opposite sign with respect to the source/sink in the origin. The two sources/sinks are positioned along the x-axis at x = δx and x = −δx, respectively. Consider the limit for δx → 0 under the condition that
\lim_{\delta x \rightarrow 0} \delta x^2 m = \mu_2
with \mu_2 finite. Consider this problem in three dimensions and sketch the resulting streamline patterns. Is there a closed streamline, which does not pass through the origin.
The potential \Phi_e for a single source/sink of strength m in 3D is:
\Phi_e=-\frac{m}{4\pi r}
\bar{u}_e=\nabla\Phi_e=-\frac{m \bar{r}}{4\pi r^3}
with \bar{r}=\bar{x}-\bar{x}_0 where x = (x, y, z) and r = |\bar{x}-\bar{x_0}| = \sqrt{x^2 + y^2 + z^2}
Since the poisson equation which leads to the potential solution above is linear, I can add the 2 sinks and 1 source together to get 1 potential:
\Phi_e=-\frac{m}{4 \pi}\left(\frac{-1}{|\bar{x}-\delta\bar{x}|}+\frac{2}{|\bar{x}|}+\frac{-1}{|\bar{x}+\delta\bar{x}|}\right)
I have to take the limit to 0 for δx and I want to introduce \mu_2 so I take:
\Phi_e=\lim_{\delta x \rightarrow 0} -\frac{m \delta x^2}{4 \pi}\frac{1}{\delta x^2}\left(\frac{-1}{|\bar{x}-\delta\bar{x}|}+\frac{2}{|\bar{x}|}+\frac{-1}{|\bar{x}+\delta\bar{x}|}\right)
From this point on I'm highly unsure about my method.
Taking the limit it follows that \lim_{\delta x \rightarrow 0} \delta x^2 m = \mu_2 and \frac{1}{\delta x^2}\left(\frac{-1}{|\bar{x}-\delta\bar{x}|}+\frac{2}{|\bar{x}|}+\frac{-1}{|\bar{x}+\delta\bar{x}|}\right)=\frac{\partial}{\partial x^2}\left(\frac{3}{|\bar{x}|}\right)
So my potential becomes:
\Phi_e=\frac{\mu_2}{4\pi}\frac{\partial}{\partial x^2}\left(\frac{3}{|\bar{x}|}\right)
From here I could proceed to calculate the velocity, but honestly I don't trust my answer enough to take the effort so I first wanted to ask whether anybody could run through my calculation and comment on any mistakes/errors!
Thanks in advance!
