Uniform plank - Supporting force
  • Thread starter Thread starter mybrohshi5
    Force Uniform
A uniform plank supported by two equal 120 N forces at points X and Y has its support at X moved to point Z, halfway to the center of the plank. The total force acting at the center is 240 N, derived from the combined forces of the two supports. To find the new supporting force at Y, the torque equation is applied, taking moments about point Z. The resulting calculation shows that the supporting force at Y becomes 80 N. Understanding torque and moment conventions is crucial for solving such equilibrium problems effectively.
mybrohshi5
A uniform plank is supported by two equal 120 N forces at X and Y. The support at X is then moved to Z (halfway to the plank center).
The supporting force at Y then becomes?
_____________________________
X...Z...c......Y
i tried to draw it above. The line is the plank, X and Y are the supports, Z is where X is moved to, and (c) is the center of the plank
I came across this as i am studying for my test and i am a little lost.
The solution says to do this:
(240 N)(1/4L) = Fy(3/4L)
and the answer is 80 N
I am confused on where this solution comes from.
Any explaining would be very helpful :)
Thank you
Well start off with X and Y being at the ends. If the system is in equilibrium there, what should be the force acting at the center c?
you are given the initial reactions; what must be the weight of the plank, and at what point does the resultant force of the plank's weight act?
The force at the center would be (120N + 120N) = 240N correct?
Is the equation used for this dealing with torque?
thanks for the help
thanks for the help
No, now you have the forces. So now you have force at the center. Now move X to Z (I don't know if you have that distance) and just take moments about any point. For example, take moments about the new position of X i.e. Z.
I don't have the distance so i believe the plank length is considered L.
I am not sure what you mean by moment.
When you say moment do you mean Moment of force = Torque:\mathbf{\tau}= \mathbf{r} \times \mathbf{F}
the terms torque, moment, or moment of a force, are often used interchangeably.
Oh ok thanks for the insight on that :)
does this seem right.
if i take the torque about point Z then
tcenter + ty = tz
(240N)(1/4L) + (Fy)(3/4L) = 0
tcenter + ty = tz
Watch your sign convention, if clockwise moments are +ve, then anticlockwise moments are -ve.
Ok thank you :)
