Rockwell hardness of valve lifters
  • Thread starter Thread starter undesiredshoe
    Hardness Valve
The discussion focuses on issues related to converting hydraulic rocker arms to mechanical adjusters, specifically the damage occurring to valve lifters and adjuster screws. The user is experiencing pitting on the valve lifter due to the adjuster screw, which has a Rockwell hardness of C45. There is uncertainty about whether the new machined set screws will prevent further damage and if they can be hardened to match the OEM components. Participants emphasize that mixing hydraulic and mechanical components can lead to severe engine damage, and caution against assuming that harder materials will always reduce wear. The conversation highlights the complexities of valve train dynamics and the importance of using appropriately designed parts.
undesiredshoe
Hey guys, I have a set of rocker arms that I converted from a hydraulic to a mechanical adjuster and I am having problems with the adjuster screw I am currently using. Whats happening is that when the adjuster screw hits the valve lifter, its digging away at the top of the lifter causing a minor pit to form. The adjuster screw tip also has had some material that has been grinded away.
I can't find any other adjusting screws in that size except for some steel set screws from mcmaster-carr. I purchased them and will get the ends machined to a round point with hopes to use them. I believe the oem hydraulic rocker arm has a hardened steel tip where it contacts the valve lifter.
So I was wondering if the machined set screws will prevent more damage to the end of the valve lifter or would I have to harden the set screws?
The set screws have a rockwell hardness of C45 according to mcmaster-carr. I have no idea what type of material the oem rocker arm is made out of.
Also, why would both the valve lifter and adjusting screw have damage? Shouldnt it only be one or the other if the hardness was different?
Thanks in advance for any help guys. Let me know if you guys are confused about anything, ill try to clear it up.
been there done that
you can not use hydraulic cam valve train components on a solid mechanical camshaft. the cam ramp is different as are the components..the hydraulic cam components are designed to work with the presence of motor oil in the lifter and this whole valve train runs a lot less harsher then the solid lifter set up which is straight metal to metal..hence the hydraulic set up is quieter smoother has less vibration...the solid bumstick set up is solid metal all the way thru and is hardened to take the abuse. if you swap out pieces and mix and match parts it will run ..for a little while...then you wipe out a lobe or lifter or maybe even a set of main bearings...do not do it!
I understand that it will be more harsh and make more noise but there are a few companies out there that have converted hydraulic rockers to a mechanical design with success so it can be done. They use adjusting screws out of pre existing engines. I took out an adjusting screw out of a honda civic and the tip feels and looks exactly like the tip of my stock hydraulic rocker.
I could have just bought one of their kits but i am a diy kind of person so I decided to design my own.
I guess my actual question is, what kind of material is the tip of the stock rocker arm? Is it simply hardened steel? Can i harden the set screws i bought to the same hardness by heating it up and dipping it in oil?
i think you will find that the manufacturer has already hardened the screws...just about all valve train parts are hardened simply to avoid warranty costs..
I probably wouldn't bother with this. The manufacturer has spent thousands of hours of engine testing alone trying to minimise valvetrain wear. Wear isn't about making everything hard, and it's not always (or even usually) the softer component that wears more rapidly. You could try hardening your new machine screws only to find that you start getting Hertzian cracking or some such under high load conditions.
Try it by all means but be prepared for some unsavoury lessons learnt.
For knowledge by going to the new job.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
