How can I dissolve dried plaster of paris?
  • Thread starter Thread starter ninapilapil
    Dissolve
The discussion centers on the challenges of removing plaster of Paris from a glass casserole used in a scale model project. Users suggest that water and time are effective for dissolving plaster, while adding acid or sugar can speed up the process. Another method discussed involves converting the dihydrate form of plaster back to its hemihydrate state by baking it at 150°F for several hours, with estimates ranging from 2 to 4 hours, but potentially longer depending on the thickness of the plaster. Microwave heating is also proposed as a method to facilitate the drying process, recommending a gradual increase in power.
ninapilapil
My groupmates and I were using plaster of paris for our Arch 10 scale model of a chair. We used a glass casserole for the first trial. Kind of stupid. We covered it with oil before putting in the mixture but when the mixture dried, we couldn't get it out anymore. How can I dissolve plaster of paris?
Chemistry news on Phys.org
Water and time will eventually get it out. Acid or sugar will accelerate it somewhat.
You can convert the dihydrate back to the hemihydrate by baking it at 150F for several, perhaps many, hours. It should then crumble easily.
An estimate of how long?
For the heating step? It should take from 2-4 hours but depending on the maximum cross section the water must traverse on the way out, that could increase significantly... perhaps as much as a day or more.
http://www.lpi.usra.edu/meetings/lpsc2007/pdf/1432.pdf"
http://cr4.globalspec.com/thread/25981/Gypsum-dehydration"
I like the idea of microwave heating. Heat slow at first and then ramp up the power.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
