Find the work done by nonconservative forces in stopping the plane.
The discussion focuses on calculating the work done by nonconservative forces in stopping an 18,000 kg airplane landing at 92 m/s on a 115 m long aircraft carrier deck. The initial calculation attempted was 18000 * 92 * 115, yielding 190,440,000 J, but this was deemed incorrect due to potential loss of significant digits. The correct approach involves using energy considerations, specifically the kinetic energy formula, leading to a final answer of -7.6 x 10^7 J. The units for the work done are confirmed to be in joules, indicating the energy lost during the stopping process.
stuckne1
A 18000 {\rm kg} airplane lands with a speed of 92 {\rm m/s} on a stationary aircraft carrier deck that is 115 {\rm m} long.
W = FD
18000 * 92 * 115 = 190440000 J
Unless it's wanting 1.9 * 10^8 = 190000000 J (which seems wrong since detail is lost)
(I don't think that's 2 significant digits.)
W = FD
The best way to solve this type of problem is with energy considerations. What was the KE of the plane just before it traps on the carrier deck? What is the KE right after it is stopped by the wire? Wher did that energy go?
it was 1/2(m)(v)^2 or something.
The answer was -7.6 x 10 ^7
Thanks!
Thanks!
Does that mean that you calculated the correct answer? What are the units of the answer?
Yes, the units of the correct answer was in joules.
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
