Expansion of a Compressible Gas
The discussion revolves around calculating the pressure of a compressible gas, specifically air, after it expands from a cylinder. The initial assumption was that the ideal gas law could not be applied due to air's compressibility, leading to the use of a modified equation incorporating the compressibility factor (Z). However, it was clarified that for air, which behaves closely to an ideal gas, the ideal gas equation can be used effectively. The compressibility factor Z is acknowledged as a way to account for deviations from ideal behavior, but in this case, it may not be necessary. Ultimately, the conclusion is to treat air as an ideal gas for this calculation.
El Moriana
Hi,
I'm trying to figure out the pressure exerted by a compressible gas (air) after it has expanded out of a cylinder for a simple conceptual design. I'm pretty sure that it's a simple problem, but I'm a little thickheaded atm. Here is my thinking so far:
Due to the compressibility of air, I assume that I cannot use the ideal gas model, hence
P1V1=P2V2 (assuming an isothermic expansion) cannot be used.
Instead, factoring in for compressibility, I get:
P1V1Z1=P2V2Z2 (again assuming isothermic expansion)
I know the cylinder used and expansion chamber and so I know P1, V1 and V2 and can calculate Z1.
This leaves me with two unknowns - P2 and Z2 - but only one equation. How do I get the second equation to solve this?
El Moriana said:
Hi,
Why not? An ideal gas is a gas and all gases can be compressed.
What is Z supposed to represent?
AM
Z is a compressibility factor. It is used to account for a gases behavior when it deviates from the ideal gas model (which uses a Z of unity). Essentially, no gas has a Z of exactly 1, but gases such as air come close enough to so as to be approximated as 1.
You were right, however. I was addle-brained at that time and for some reason I visualized the air acting as a liquid, where pressure changes the volume only slightly (why? I will never know.. *sigh*) and saw Z as the way to compensate for that. The solution was simply to assume air as an ideal gas and us the normal ideal gas equation.
Thanks for replying before and apologies for the late reply and the sub-par question. =)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
