What is role of mass participating factor while doing Modal Analysis?
The mass participation factor is crucial in modal analysis as it helps identify which modes significantly influence a structure's dynamic response. The number of modes required for accurate analysis is determined by the degrees of freedom and the frequency range of interest, typically including modes up to 2x or 3x the highest frequency studied. Care must be taken when dealing with closely spaced frequencies, necessitating tests with varying numbers of modes to ensure consistent results. Modal models can achieve high accuracy with fewer modes, making them efficient for analysis. Understanding these factors is essential for effective modal analysis in engineering applications.
anoopsrikanth
What is role of mass participating factor while doing Modal Analysis and how can we come to a conclusion that how many number of modes are required for a particular Modal Analysis.
Please help me .
Please help me .
Number of modes depends on number of degrees of freedom.
One use of modal analysis is to understand which modes of a structure are causing a particular dynamic response. Mass participation factors are one way to measure which modes are important and which are not.
You need all the modes in the frequency range that you are interested in, plus a safety margin. Including modes up to 2x or 3x the highest frequency you want to study is often a reasonable choice. If you have many modes with closely spaced frequencies, you need to be careful about this - for example run the model with different numbers of modes and check the results are similar.
The total number of degrees of freedom in the model (or the real-world structure) is irrelevant. The number of modes used is often much smaller. One of the advantages of modal models is that they can give good accuracy with a small model size, once you have found the mode shapes and frequencies (and that only needs to be done once).
Thanks
what is g-load analysis doing a chassies g-load analysis for condition lcf 5g-x,5g-z and 4g-y help me what actually it means.
possiblly with somw simple example
I need the MATLAB code for modal analysis of a MDOF system.please help me
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
