Having trouble writing down a metric in terms of metric tensor in matrix form?
zeromodz
Can someone please explain to me how exactly you write down a metric, say the FLRW metric in matrix form. Say we have the given metric here.
ds^2 = dt^2 - R(t)^2 * [dw^2 + s^2 * (dθ^2 + sin^2(θ)dΦ^2)]
Thank you.
Let the coordinates be q1,q2,q3,q4.
The line element will be a sum of terms like C12dq1dq2.
In matrix form, C12 will be in row 1 column 2 of the matrix.
Edit: See Rasalhague's post for the correct version. I forgot the 1/2 for the off-diagonal terms.
In your example, if q0 = t, q1 = w, q2 = θ, q3 = Φ (where superscripts are indices), then the matrix of coefficients will be as follows, with superscript 2 denoting an exponent:
\begin{pmatrix}<br /> 1 &amp; 0 &amp; 0 &amp; 0\\ <br /> 0 &amp; R(t)^2 &amp; 0 &amp; 0\\ <br /> 0 &amp; 0 &amp; (R(t) \cdot s)^2 &amp; 0\\ <br /> 0 &amp; 0 &amp; 0 &amp; (R(t)\cdot s \cdot \sin(\theta))^2<br /> \end{pmatrix}
= diag(1,0,0,0) - R(t)2[diag(0,1,0,0) + s2(diag(0,0,1,0)+diag(0,0,0,sin(θ)2)].
Here diag(a,b,c,d) denotes a diagonal 4x4 matrix with diagonal entries as indicated, from top left to bottom right.
In general, given an expression of the form
ds^2 = ...,
where the values of the indices are not equal, the scalar coefficients in each term of the form
A \, dx^\mu dx^\nu \enspace (\text{no summation} )
(EDIT: Ignore the words "no summation" - a relic of previous version which I forgot to remove before posting. Sorry.) correspond to matrix entries
g_{\mu\nu} = \frac{1}{2} A.
And where the values of the indices are equal, the scalar coefficients in each term of the form
B \, (dx^\mu)^2
g_{\mu\mu} = B.
Rasalhague accidentally missed some minus signs:
\begin{pmatrix}<br /> 1 &amp; 0 &amp; 0 &amp; 0\\ <br /> 0 &amp; -R(t)^2 &amp; 0 &amp; 0\\ <br /> 0 &amp; 0 &amp; -R(t)^2 \, s^2 &amp; 0\\ <br /> 0 &amp; 0 &amp; 0 &amp; -R(t)^2 \, s^2 \, \sin^2\theta<br /> \end{pmatrix}​
Oopsh... Thanks for the correction, Dr Greg!
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
